Question about Runco CL-510LT Multimedia Projector
Unit will not Turn the lamp on. It powers up and you can hear the fans blowing you can also hear the clicking noise of the lamp trying to be started. It will do this about three times. Then I get a red blinking light with a constant green light lit. The fans continue to blow for about 3-4 minutes then the unit shuts down. I opened the front cover and removed the bulb.It doe's not appear blown.I also cleaned all the dust out of the unit. There was no visable signs leading up to this action. I was watching tv one night everything looked perfect then the next morning I went to turn on the unit and it would not work. Any suggestions
3 Suggested Answers
  • 75 Answers
SOURCE: unit not powering up. New lamp installed but
a couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Posted on Jun 06, 2010
paul4265
  • 592 Answers
SOURCE: On my runco vx101c ,
Hi.
It sounds to me like the new bulb that you've purchased is just as bad as the old one that you took out.
If this was a regular flat screen tv, instead of a projector, then I would say that it was a cpapcitor problem.
But you said that the problem didn't come around UNTIL you replaced the bulb.
I wonder, does the bulb have a special way that it needs to be seated in it's plug?
It could be that it can only go in one direction in order for the contacts to work properly.
Now, it could be that, in removing the old bulb and replacing it, you might have damaged the solder for the socket, preventing the plug from getting a good connection.
Also, sometimes when replacing bulbs, other parts such as resistors can fail.
This can be to voltage instability, electrostatic discharge, power failures, and so on.
I would take the new bulb out, and take it and the old one to Fry's, or to BestBuy.
They both seem to have a rather well stocked supply area for bulbs, it could be that even though your bulbs might LOOK the same, they may be quite different as to the way they are made on the insides.
I hope this helps you out some, and good luck!
Posted on Mar 14, 2011
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Wont turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 22, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Grand Wega KFE50A10 has a black screen. When started the power/standby light flashes green and the fan starts. After a period the same light starts flashing red in blocks of five. What does this...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2400 you can find it here:http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm?Click=48173 .Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Runco CL-510LT Multimedia Projector Logo
52 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
