Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
My Hp w1907 is doing crazy things. First of all it won't stay on. I have to keep turning it on and off to get the screen to stay on, and now the menu keeps poping up and doing things like turning the volume down without me touching it. Please help its very annoying
Aww ****. I thought this had a solution but it didnt. Almost the same thing is happening to me. besides the menu thing. It keeps turning on and off. and this is right after my warranty ran out. I think HP is trying to **** us .-.
Posted on Oct 02, 2010
Hp w1907 monitor won`t turn on
first remove thecover and remove all the power connectors from the smps the hold the 24 pin poerconector and short the green and black wire and see wether the smps fan is working if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots
Oct 02, 2011 | HP w1907 LCD Monitor
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
Hp w1907 has white screen in vga and dvi-changed computers doing same thing-tried another monitor and it works on both computers
The all white screen indicates loss of 5 VDC to the LCD panel. Either the connector is not plugged in good or (more likely) the panel itself had failed. They can develop a short that blows the 5 V fuse on the panel. Replacing the fuse normally does not fix the problem.
Monitor Mike
Apr 30, 2010 | HP w1907 LCD Monitor
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
My HP w1907 monitor blacks out after turning it on. It only stays on for one second. What is wrong?
I've seen something similar in some Iiyama screens recently in the office, it was caused by failing capacitors in the power supply. I managed to replace these with a bit of soldering iron work and the help of this site http://www.badcaps.net/
Be careful if you do choose to take a look inside your screen though, there are some nasty voltages in there.
Nov 25, 2009 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
HP W1907 Won't stay lit
You may try to rule out the monitor problem by using another monitor. If it does it with another monitor than it may be your video card. Also make sure you check your cables to ensure they are connected properly.
Aug 02, 2009 | HP Computers & Internet
The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Mar 04, 2009 | HP w1907 LCD Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
