Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG Tromm front loading washer is not dispensing the detergent. I have to manually add it during the wash cycle. What might be the problem?
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
drsn
  • 42 Answers
SOURCE: LG Tromm - WM2688HNM - Detergent dispenser full of water & some detergent after wash.
sounds like you have calcium build up, this happens alot with LG's. need to take out the dispenser and clean the calcium with industrial lime away, that only works good for me, but others will do, also use a sharp object, like a ice pick or finishing nail, to scrape off any left over hard residue.
the calcium will clog all the holes in the dispenser.
if this doesn't solve your problem, then there is one thing left
just email me and ill give you the other solution.....
drsn777@hotmail.com
dave
Posted on Dec 12, 2008
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
OMy front load LG washer is gushing water from the detergent dispenser!! Repair suggestions???
Some washers are designed to flush the detergent dispenser to eliminate residue after each wash cycle.
Feb 02, 2015 | LG 3.9 cu. ft. Front-Load Washer, Metallic...
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Lg tromm washer leaks from detergent drawer
my washer also was leaking from the dispenser and I had a cap from one of the detergent bottles stuck in the inlet hose. Don't know how it got in there but glad I found it so if your washer leaks from the soap tray it could be a cap from your detergent bottle stuck in there.
Nov 04, 2012 | LG WM2688H Front Load Washer
Jul 20, 2009 | Washing Machines
Water and detergent are in the bin after wash cycle
check to make sure water lines are not clogged and detergent tray is not caked up
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water being left in the dispensers when the washer cycle is done
Water in the fabric softner slot is normal, but for the detergent slot you have to clean out with a tooth brush if you can't get the tray out. If there is water there it is quite a serious block, which is affecting your wash.
Mar 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Even though you want your washer completely leveled, you need it to be leveled but slightly tilting to the back.
We were having this issue after we releveled our washer because of vibrations during the spin cycle. Once we made a slight adjustment, the problem was solved.
Oct 27, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
278 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
