I have a TI 83 Plus and when I turn it on the answer is really faint...I already tried to darken the screen and there numbers are all over the screen...if the number is 3220 the 32 are in the top line and the 2 is on the next line and so forth...I think its dying and I have no idea why, but I did have a TI 86 before this and right before it died I had the same problems where the screen went really faint and it started malfunctioning. Also, when I press the clear button it is unable to clear to chaos all over the screen...there are other characters which are just showing up on various parts of the screen along with only parts of the numbers showing... basically it looks like partial lines which make up the numbers.
Any advice about how to fix it would be great...thanks for you help.
The screen may be too dim to read. Try pressing 2ND->Up arrow key repeatedly while the calculator is turned on and it may darken the screen enough so you can read it.
The screen may be too dim to read. Try pressing 2ND->Up arrow key repeatedly while the calculator is turned on and the screen should start to darken so that you can read it.
Try adjusting the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key to darken the text. If you go too far, use the 2ND and up-arrow keys to lighten the text.
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the up-arrow key for a couple of seconds to darken the screen. If you go too far, repeat the process using the 2ND and down-arrow keys.
The screen may be too dim to read. Sometimes when the batteries are low, the screen automatically dims itself. The problem is, it doesn't undo that when the batteries are replaced. Try pressing 2ND->Up arrow key repeatedly while the calculator is turned on and the screen should start to darken so that you can read it.
Turn the calculator on. Press and release the 2ND button. Press and hold the up-arrow key to increase contrast/darken the screen or the down-arrow key to decrease contrast/lighten the screen.
Could be that the contrast is turned up. Try turning the calculator on and then pressing the 2nd key and hold down the down arrow. This should lighten the screen if there is a contrast problem. You can darken the screen, sam procedure, just use the up arrow. Hope this helps.
