My computer told me, among other things I don't remember, that "the system has stopped." Now I can turn the thing on or off, but when it is on, all that comes up is a blue screen. There are no prompts or messages, and it won't respond to any input at all. Is there anything I can do to make it work?
    Scholar:
  • 54 Answers
Have you recently installed new hardware? If yes then try removing that hardware.
If not, then try switching memory and/or videocard if possible.
If you have multiple memory modules, try booting up with only one module.
Usually the blue screen has messages thet tells you where the error is developed.
Hope this works.
Posted on Sep 17, 2010
Air Flow stopped working on my car. I was driving a couple of days back and when I turned on the air controls, the air flow stopped coming through. I took it into the shop and was first told it is possibly...
Best way to make sure the right thing is fixed is to bring it to a dealer. Usually the only thing that stops the air flow is a malfunctioning blower motor, but what causes this is usually the blower motor resistor pack.
Jun 02, 2013 | 2004 Honda Accord
98 voyager computer reset?
after a battery is died or remove/replace the computer needs to run a self test on all the sensors and emissions test will not run test until what they call monitors have run so that is a normal function and low freon charge shuts the system off to prevent compressor damage the light will flash instead of turning on
Aug 01, 2012 | 1998 Plymouth Grand Voyager
Has intermittent start, starter does not turn. If I turn the key a dozen times it will then start. It will start ok for while. It will do the same thing again. Yesterday we push started it. Took to a...
Bad battery, bad cables, bad starter, bad starter switch, bad electrical connections. One thing for sure, you need a better mechanic. Don't go back to that guy.
Apr 22, 2012 | 1993 Saturn SL1
I changed the battery in my 2001 grand am ....now it won't start
mine does the same thing, but my security light flashes. I was told that it is the security system on the car not recognizing the key. The key I am using is the original key for the car though. I was told that a quick (but not so quick) fix is to open the door, put the key in, turn it on but don't start it.... set for roughly 10 minutes so the car will reset itself. It works everytime but is a pain in the ****. Was told the only way to completely fix the problem would be to put a new motor in it.
Dec 05, 2011 | 2001 Pontiac Grand Am SE
Mpcheeseman it wont ever turn my cd on now so i cant boot from it
Oh--now I understand. You are using the restore disks for your computer.
It sounds like you did the correct thing, but try this:
Do the whole thing over. After the last disk is finished and it wants you to restart the computer, remove the disk from the drive and see if it boots OK. It almost sounds like you were told to reboot the computer and when it started it asked you to press any key to boot from the CD and you did. Don't do that--just let it go on its own. Let us know what happens.
Oct 15, 2011 | Acer Aspire 3004WLCi Notebook
1996 Chevy Tahoe air conditioning not blowing cold air
That "thing" is part of the compressor clutch. When it’s spinning the clutch is engaged, when it stops the compressor is off. If it’s constantly cycling, you probably don’t have enough freon in the system. But remember, however the gas escaped before, it will escape again, unless you fix the leak.
Jul 14, 2009 | 1996 Chevrolet Tahoe
2000 dodge grand caravan AC stinks
I don;t know who told you the coils would leak and let leaves in but don;t let them work on your car.
2 things to do.
1 make sure the drip tube is not clogged up. If it is water will build up and could mold. Should be a small hose coming off the firewall under the car. Just make sur eit is open and clean.
The next thing is to remove the AC/Heat fan and look in there. You can look in there and smell and remove any leaves/dirt you fine.
Mar 27, 2009 | 2000 Dodge Grand Caravan
Power supply
if i remember this psu has a wierd wiring pin out. best thing to do is upgrade all or none.
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
