Question about Admiral Washing Machines
Admiral washing machine keeps filling up and will not stop till I turned my water valves off, and then it will not wash the clothes but will spin them .
  • Admiral Master
  • 17,129 Answers
The water level sensor is faulty. After the inlet valve is opened the program controller needs the signal fromt he water level sensor. Thi is normally a pressure switch and as the water builds up the tub through a small opening the water flows through a tube to trigger the switch. So find out the pressure switch and replace. Only once the sensor clicks will the program proceed to wash . Otherwise you can spin becasue the water level sensor need not work for spinning as the level is down.
Posted on Sep 17, 2010
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Wash machine will not stop filling/no matter what setting the level is set.it will spin out. How do I fix this. It is an admiral capacity plus. model # LNC6760B71 serial # 20672581CL
Most probably an inlet valve fault. Could be the water level sensor hose has diconnected, or the drain hose is too low, and is allowing water to flow through into the drain.....Check drain hose......If water flow is not stopped when you unplug the machine, it's probably a valve.....Not a big job........Good luck......Nomess
Mar 24, 2010 | Admiral Washing Machines
Water level rose quite high in machine and machine keeps bleeping quoting E16. It won't cancel itself. can you please help? My washing machine is WD71. prior to this after a wash and spin, I would take out...
check the electronic inlet valve I dont know the code but the symptm sound like a faulty leaking inlet valve
as a temp remedy you shoud have a inline isolator check valve this is where the water fill pipes connect to turn them off this will stop the machine from flooding untill you are able to seek repair
Jan 16, 2010 | Washing Machines
The washer water won't turn off once it has filled for all three load sizes.
Might be the water inlet valve at the back of the machine where the hose connects too, replace the valve and see if that fixes the prob
May 09, 2009 | Admiral AW22 Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
463 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
