Question about Cosco 10-T58 Portable Crib
One of the clips that holds the board up is missing where can i buy another one at
One of the metal bracket is missing where can i buy another one for COSCO 10-T58
Posted on Oct 03, 2012
How do I repair the compass /thermometer upper console?
Tools Needed: Philips, torx bits, soldering iron, solderbr>
Steps to Fix:
1. Open sunglass holder
2. Remove screw holding console to ceiling
3. Grip and pull down on the front (windshield-end) of the console. It will take a bit of pressure for the clips to release.
4. Unplug electrical harnesses
5. Ensure the you still have 2 metal clips attached. If not, the missing one will be laying in/next to the clip-hole
6. Remove the 3 Torx screws holding the display/board
7. Unclip the plasic cover from the board. Be careful. They break easily
8. Locate the '510' resistors and look for disconnection. Mine was very easy to see.
9. Press down resistor and solder broken end. I chose to solder both ends of both 510s to make sure I won't be back in there.
10. Reassemble. It may be worth testing before you snap the clips back into place.
Overall its a VERY easy fix that can be done by just about anyone.
20 minutes & $.10 of solder is better than the $900 that Toyota wants.
Oct 08, 2014 | 2009 Toyota Tacoma
Disassembly nuvi
The clips are part of the connector and can not be purchased separately, however it is possible to remove a clip from another connector and install it on the connector with the missing clip. It takes a steady hand and there is a trick to get it on. We've done it many times in our repairs for our customers.
Jun 01, 2013 | Garmin nuvi 650 GPS Receiver
Missing one clip on my air filter box. Can I buy just one?
Hi Pam, Try a breakers yard. You will probably get a clip free of charge or maybe even a replacement (box) housing. Regards John
Jul 21, 2012 | 2005 Toyota Highlander
1992 olds 88 wont start done put on a new cam & crank sensor & a control module but i have noticed my magnat is missing please help
if its missing, you need to replace the cam gear, unless you can buy a magnet seperately and a clip or way to hold it in the gear. I have not seen one in 10 years, so I cant remember how it was held in.
Sep 07, 2010 | Oldsmobile 88 Cars & Trucks
Picture is showing in BLACK AND WHITE now. Can I buy just the COLOR WHEEL iot repair unit??
yes. part number 525-0146-00. you can get it through any infocus authorized service center. some won't sell parts to you. try av solutions in rochester, ny. i know they will.
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
Oct 05, 2009 | InFocus ScreenPlay 4805 Multimedia...
Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
Jul 26, 2009 | Bugaboo Frog Stroller
Toshiba M35X S161 Ribbon Connector
You can buy another one cheap at a computer retailer, maybe. Search eBay too. There are various good things available there.
Nov 30, 2008 | Toshiba Satellite M35X-S161 Notebook
Convergence IC replacement
some have plastic clips that need to be pressed back to release the board. There should also be 6 screws holding the D board to its frame.
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Cosco 10-T58 Portable Crib Logo
77 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
