Question about Dymo RhinoPro 5000 Thermal Label Printer
I get a Error 6 Print error on my RhinoPro 5000 screen and I tried changing batteries and print cartridge but still not working
  • 36 Answers
SOURCE: cartridge error
try reseating the cartridge & also reseat the power brick assembly.....also if u hv the factory installed cartridges....try installing those & chk if u still get the error...
Posted on Jul 06, 2008
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
Posted on Jan 01, 2009
Roynice152
  • 88 Answers
SOURCE: Printer Error
Go to control panel>printers & faxes. Open the printer, go to the top of the tool bar>printer>properties>align cartridge.
Posted on Jan 09, 2009
yooperbud
  • 8637 Answers
SOURCE: Dell 926 Printer, Error 1203,
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
giovarodrigu
  • 24 Answers
SOURCE: u051 install the print head error reading, do I
the printhead it is attached at each cartridge, so, there are two options: a) cartridge damageds or b) bad read cartridge contacts.
Do this, take out the cartridges, check if the contacts are clean and dry, then be sure to fix well again in the printer, if an error message appears, push the cancel button by 6 seconds, this deactivate the ink level sensor.If the error stay, 6 seconds 1 more time, if not works, I think that one or both cartridges are damaged, try with a new pair.
Posted on Jul 25, 2009
What is error B200 when attempting to power up
http://www.printerdiary.com/2011/09/canon-error-b200-how-to-fix-it.html
Error B200 on Canon printers is a print head error. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Mar 24, 2012 | Office Equipment & Supplies
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
U051 install the print head error reading, do I need to change the cartridges, or the print head
Jul 14, 2009 | Canon PIXMA MP470 All-in-One Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Incomplete print job
Cartridge Changer Errors are series. Did printer work before you installed XP?
Oct 10, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Sep 06, 2008 | Alps MD 1000 Thermal Printer
ALPS 5000
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Sep 04, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
Did you pack the printer correctly before moving? When you got the printer, it would have had a packing piece preventing any carriage movement. If you did not put this in place before packing the printer for the move, you have most likely damaged the printer beyond repair.
May 22, 2008 | Alps MD 5000 Thermal Printer
Dymo RhinoPro 5000 Thermal Label Printer Logo
1,707 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
