Question about Labtec Logitech Cordless Desktop Pro (967115-0403) Keyboard
My keyboard stop working. my computer keyboard stop working, there is no display in the board.
  • 30 Answers
Check the connection to the computer it might be loose
please insert it back and restart
Posted on Sep 17, 2010
Black screen delld600
Several things can cause your Dell Latittude D600 laptop's LCD screen to stop working.
Two of the most common causes relate directly to the inverter board and the backlight lamp.
The inverter board is a thin circuit board placed inside the LCD panel.
It's main function is to transfer power from the motherboard to the backlight bulb inside the LCD screen.
If the inverter board goes bad or the backlight lamp burns out, the screen will appear dim or eventually go completely black.
Turn off the laptop, unplug the power cable, close the LCD panel and place the laptop face down.
Remove the battery pack from its compartment on the bottom of the computer.
Flip the laptop back over and reopen the display panel all the way until it is in a 180-degree position.
Insert a flat head screwdriver into the right side of the keyboard bezel.
This is the plastic strip situated above the top row of keyboard keys. Carefully pry the bezel from the laptop.
Remove the two Phillips screws located above the top row of keyboard keys.
Grasp the top edge of the keyboard, tilt it upward and lay the keyboard face down on the palm rest area.
Unplug the keyboard's ribbon cable from the motherboard connector.
Carefully remove the entire keyboard from the laptop.
Disconnect the video and speaker cables extending from either side of the LCD panel to the motherboard.
Loosen the Phillips head screws on each LCD panel hinge.
Carefully lift the entire LCD panel off the laptop's base.
Relocate the panel to a flat work surface, and place the panel so the screen is facing upward.
Use a thin, flat head screwdriver to pry the rubber screw covers from the LCD panel's front plastic cover.
Remove the Phillips head screws revealed by the rubber covers.
Carefully remove the front plastic cover from the display panel.
Locate the inverter board situated below the LCD screen, inside the bottom edge of the display panel.
Disconnect the two cables from each end of the inverter.
Remove the two Phillips head screws fastening the inverter to the display panel.
Carefully lift the inverter board out of the display panel, and dispose of it.
Repeat this procedure in reverse to install the new inverter board, and reassemble the laptop.
Hope this helps
Oct 23, 2012 | Dell Latitude D600 Notebook
My laptop Acer asphire displays the symptoms of a stuck key error, but when I removed the key board the same problem occurs. the nuber 5 key still stuck.... but there is no keyboard installed anymore.
Since I see that you are comfortable with your computer I would like to recommend trying two different things. First off try using an external keyboard. See if this stops the error. If that does not then take the computer apart and remove the CMOS battery from the motherboard.
Jun 04, 2010 | Acer NSK8458AN Keyboard
Can anyone tell me why a keyboard on the CQ50 would stop working after opening the case? I replaced the display in my CQ50, something I have done several times before with other laptops. When i...
Are you sure that you have inserted the strip connector correctly into the motherboard connector? If not fully inserted before closing the pressure clips it may not connect properly.
Mar 19, 2010 | HP Compaq Presario CQ50-110US Laptop
Intellistation e pro acts as if booting, but doesn't
Its nothing but the port of your display cable in computer tower and the display card. If its inbuilt (on board) display card then the slot where the extention is linked. If you can then just open the tower and change the slot of the display card. 100% gurantee it would work.
Jul 28, 2009 | IBM IntelliStation E Pro 2D PC Desktop
Laptop keyboard not working when LED Power board is connected.
I agree. Your best bet if you don't know what you are doing is to find a repairer.
Jul 07, 2009 | Intel 430180-001 - HP Pavilion dv8200...
chances are there have been short circuits on the keyboard controller. better bring it to a service center
Jul 07, 2009 | Computers & Internet
Its a Question does the Keyboard if its not working keep the com
better recheck the vga connection of your LCD and the plug of your keyboard.actually, the very first time you boot the pc the you can see that the monitor is functioning if its registering the memory and the graphic card you use right?once i had that problem.i cleaned the memory block,i mean the ram memory(sdram/ddr).until now my pc is ok.
May 15, 2009 | HP Compaq Presario SR2150NX PC Desktop
KEYBORD PROBLEM
If your keyboard is not working right there are two suggestions I have to see if the problem is with the keyboard or the computer. If you have access to another computer I would plug it into that and try it out. If it works fine there then you know the issue is with the computer. If it doesn't then you may want to talk to the manufacturer if the computer is under warranty to get a free keyboard. If it's not under warranty you may want to pick up a new key board. They are only about $10 - $15.
If the keyboard seems to work on another computer it is likely an issue with the computer. One possibility could be the keyboard drivers. This is more common on keyboards with buttons alone the top to turn the computer on/off and open Internet Explorer. If this is the case see if you still have the drivers disk that came with the computer and use that to reinstall the drivers for your keyboard.
If you reinstall the drivers and it is still happening the best way to find what is causing the issue is to keep an eye on what you are doing when the keyboard stops working. Is it in Internet Explorer? Is it in Notepad? Is it in Windows Mail? And if it stops working in one of these programs does it work in other programs and just not that specific program? This would indicate that the issue is with that program and not with the keyboard or Windows.
I hope this helps!
Kenny
Mar 10, 2009 | Lenovo 3000V200 Laptop
Mouse and keyboard aren't working
have you tried downloading a newer driver for your computer? you might have to find drivers for both the mouse and your key board. make sure your numlocks is on for the keyboard to work, and make sure that in your control panel under hardware and sound check their for your mouse connections.
Jan 24, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech keyboard won't work
My key board stopped working. I replaced the batteries and I have know use of it. It will do nothing.
Jun 09, 2008 | Logitech 967437-0403 Keyboard
Labtec Logitech Cordless Desktop Pro (967115-0403) Keyboard Logo
67 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
