Question about Toshiba 65HM167 65" Projection Television
Yes, I have the same problem. A bunch of white dots, about the size of a pin head. They also increase daily
    Sergeant:
  • 171 Answers
This problem is coming from your DMD board it looks like some of the micro mirrors are getting stuck in the on or off position you need to replace the light engine system the problem will only get worst with time like you have noticed
http://www.howstuffworks.com/dlp2.htm
Posted on Sep 17, 2010
65" mitsubishi small white dots started with 3 and increase daily. what to do?
This problem can show up if there is a problem with your HDMI cable. See if problem exists with antenna signal. If it is only on input from HDMI input, change to a new cable.
Sep 21, 2013 | Samsung HLR5067WX 50" Rear Projection HDTV
My television has a bunch of white dots on the picture screen and they are increasing
Since it is not the model listed here on most DLP LCD rear projection it means the optical light engine is going bad--
Apr 28, 2012 | Mitsubishi WS-65313 65" Rear Projection...
I have the Toshiba 65hm167 DLP, It has a bunch of white spots on the screen and they increase in number daily. I have read of this problem on other T.V.'s but not this one. I have also read several...
Yes,this problems is the Light projection Engine.The chip is bad.This happen to many models of tvs in the industries.Sony,Samsung,Mishibishi and Toshiba they all use the same IC chip.Call Toshiba make kind of deal with them,help u replaced the chip or the Light Engine it self.This problems is not new many people went to You Tube **** about this problems.
Sep 03, 2010 | Toshiba 65HM167 65" Projection Television
HP 5470c scanner leaves lines on the scanned
This is often caused by dirt or dust on the imaging head. This requires taking the unit apart in a CLEAN area and wiping off the head with lens cleaner and a microfiber lens cloth.
Apr 16, 2010 | HP Scanjet 5400c Flatbed Scanner
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dot has appeared on the screen and seems to be getting big
ok. unless your very good with electronics you need to call a repair man the colors got unalined.
Feb 12, 2009 | Philips 60PP9202 60" Rear Projection...
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Nick in LCD screen
If it's a stuck pixel, give it a sharp, firm tap with your fingertip a couple of times... this will make it go away for a while.
I have one on my monitor that is stuck on blue and this works.
Feb 03, 2008 | Televison & Video
Blue dots
You have a bad blue LCD in the light engine. Replacement of the light engine is the only fix and it usually will continue to get worse over time
Feb 13, 2007 | LG RU-44SZ51D 44" Rear Projection...
Toshiba 65HM167 65" Projection Television Logo
800 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
