Question about Toshiba Computers & Internet
Toshiba Qosmio G20-117 laptop computer. The display has developed a thin, vertical white line the entire height of the screen about 2cm from the left-hand edge of the screen. Is this a software (screen driver) problem or a hardware fault?
  • 300 Answers
It's a hardware fault, you will normally notice if you push on the screen at the top of the line it will disappear, unfortunately you will have to replace the screen.
Posted on May 18, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Vertical thin blue line in center of my Toshiba screen
The screen would have to be replaced in order to resolve the problem. Avg cost of screens are around $140. If under warranty contact manufacture.
Apr 20, 2010 | Computers & Internet
Video card went out on laptop. Replaced Motherboard. Works great, but now a thin line vertically on monitor. Hooked up to outside monitor and no line. Suspect LCD going out?
The problem description provided by you clearly reveals that the issue is with the LCD screen and a replacement is required.
This is a common problem. Most people just live with it. You can make it less noticeable by changing your background color on your desktop to a pure white color.
Oct 21, 2009 | Toshiba G15-AV501 Qosmio Notebook
Display has vertical white lines. Hook up a external flat screen and it works fine . Toshib Qosmio g25
this indicates you have a bad screen, and if you press around on the back (top) of the computer display the lines will disappear until you take your hands off the area effected, and the screen needs to be replaced.
Jul 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Qosmio g30 , problem with boot up screen
try the following
update your video graphic drivers,
try with another ram,
if still you have problem try to repair or reinstall the os
Jan 17, 2009 | Toshiba Qosmio G25-AV513 Notebook
White vertical line
That is either a faulty ribbon cable to LCD display, or a defective lcd display itself.
In both cases tha computer must be taken apart and part replaced to fix the fault.
Parts are commonly found on Ebay, or can be ordered from toshiba.
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Display problem
could be 2 main causes, either the LCD converter under or behind the screen under the beizel has failed and is messing up the display, or simply the sreen could have been cracked at one point, either way these parts have to be obtained from toshiba.. EMPR do toshibas spare parts, if you are in australia
www.tosh.empr.com.au
Dec 10, 2007 | Toshiba Qosmio G35-AV600 Notebook
Computers & Internet Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
