Question about Microwave Ovens
Aim sceptre 32E how do I set the clock? Turntable is not turning?
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Turntable will not rotate, clock setting.
Return item to the place of purchase, it is clear this is a manufacture defect.
Apr 03, 2012 | Microwave Ovens
The 'turntable on' feature does not work it reverts to 'turntable off' each times it is set. Please advise
If the display is changing by itself despite your pressing the turntable pad, i would say the turntable pad is failing on the keypad.
If that doesn't work, leave it unplugged for about 5 minutes.
Then if it still fails, you may have a failing keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
How do you alter the clock time on these?
There should be a clock set for the time.Some microwave you have to set the time and then push the number 5 buttom to set it. not sure with this one.
Mar 29, 2009 | Sharp R-1480 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
