Question about Hayward SAND FILTER, PRO SERIES
After backwashing and turning on the filter back on, brown water comes out of the lines back into the pool. What is causing this?
  • 8 more comments
  • vincelori Sep 18, 2010
    Please excuse my ignorance on this, but we are not the original owner of the house, and I'm not sure what they did. However, after taking a closer look at our sand filter, I noticed that the only part that looks like it is a Hayward Sand Filter is the tank the holds the sand. The motor and such are from KB Pool supplies, which is no longer in business. The actual motor is located off to the side, hence all the white pvc pipes that are coming out of the sand tank. I do see two valves that look similar to the image you sent me, however neither of them has any markings on them other than the word inlet. If I ask a local pool tech to take a look at my unit, should they be able to figure if we have the ability to rinse the valve prior to going back to filter mode?
    Okay, please pardon my ignorance, but this unit came with the house, so I don't know much about it. After taking a closer look, I see that the only part of the sand filter that is Hayward is the tub that holds the sand. The actual filter motor has a KB Pool label. This is why I don't see any valves like you are describing. The actual motor/filter sits next to the big tub. I do see two valves that look similar to the image you sent, but there is no writing on them. Do you think if I hire a pool tech to come take a look that he would be able to tell me if I have the ability to rinse after a backwash before turning the filter back on?
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
If it is a short burst of brown water it is because you are not rinsing the valve prior to going back to filter mode. After backwashing you should go to rinse. Power the pump for a couple seconds to remove dirt from the valve itself, then power off and switch to filter mode.
If it is an ongoing problem for more than a moment you will need to inspect the diffuser gasket for damage that could allow the dirt in the filter to return to the pool thru the return line.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 17, 2010
  • 9 more comments
  • vincelori Sep 17, 2010
    I don't believe we have a rinse option on our pump. It is a S244S Hayward Pro Series. If we have one, I can't find it.
  • John Prohaska
    John Prohaska Sep 17, 2010
    It is on the valve one setting counter-clockwise from filter.
  • John Prohaska
    Page 4 of this manual talks about your valve settings.
    Your valve layout:
    No, I don't have any such valve settings on my filter. Any other suggestions?
  • John Prohaska
    Your filter should look like this...
    If you do not have a valve like the one in the circle, what do you have there that is allowing you to backwash the filter?
    It is just a white PVC round part that has a open and lock setting.
  • John Prohaska
    Ahhh...someone has replaced your variport valve with what is called a push/pull valve. It is likely off an old Baker filter or you have a very old Hayward. In either case you only have filter and backwash mode. The problem is that no matter how long you backwash you end up getting a burst of the remaining dirty water back to the pool after you are done unless you rinse the valve/filter. Your setup will not allow that. You can try to backwash longer but it will only minimize the burst, it is unlikely to eliminate it. You can go on as normal or refit the filter with a valve like the one shown in the previous post and therefore rinse. Over the years most of those push/pull valves I have come across work well enough that the burst is minimal and the customers just live with them. If it that big of a concern you'll need to refit the valve...your call.
  • John Prohaska
    Just to clarify then, your filter looks similar to this:
  • John Prohaska
    John Prohaska Sep 18, 2010
    It may be in your best interests if there is more than the filter issue you want some guidance on. If it is only the filter, can you take a digital photo and either post it here or email it to me using the contact feature found on our pool web site? If you can please visit www.arrowpools.net. Fixya's site limits file postings to 150K which is probably too small for a color photo.
    John
    Yes, that is what our filter looks like, except the top ring is white. Should I still have a rinse option?
  • John Prohaska
    No, just backwash. You can replace the valve you have with one like that shown in the filter black and white diagram. I imagine it would run about $90 for the valve and if you hire a pool guy or plumbing to connect it that would be an additional $100 or so. Is the burst of dirty water worth $200? That is a question you would have to decide upon.
How to backwash sand pro 550
turn filter off turn multiport to backwash turn pump on you should see water coming out of the waste line (make sure you have a hose on it with clamps) run for a coupleof minutes until water in sightglass goes from dirty to clear turn off pump turn multiport to rinse turn pump on run for 30 sec then turn off turn multiport to filter then turn back on thats all
Jul 17, 2014 | Hayward SAND FILTER, PRO SERIES
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
How do i eliminate a dark brown powdery substance from my pool water
it sounds like iron in water use metal sequestering agent it will let filter pick it up vacuum it to waste
Oct 25, 2017 | Pool & Spa
Why does the material i vacum up come out the return??
If you are vacuuming a lot of debris or algae, you need to vacuum to waste. 1. You'll turn the equipment off, 2. You'll turn the valve to waste, 3. Turn the equipment back on, and 4. Vacuum the pool like you normally would. Only this time, the debris and dirty water goes out your backwash/waste line. You also don't have to backwash and rinse afterward because none of the debris went inside the filter.
Any time you vacuum up just a small amount of debris, you'll vacuum on filter and then backwash (30-60 seconds) and then rinse (about 30 seconds).
Jun 12, 2011 | Hayward SAND FILTER, PRO SERIES
I have a Hayward S310T filter. It's been running 24/7 for over a month. The water does not appear to be clear, even after floccing. How do I tell if the water is being filtered or if the filter is...
Backwash the filter. If the water coming out of the backwash line is not dirty you need a sand change. If the water is dirty you need to continue let the water filter and back washing once a week. Also make sure the six way is on filter and not recirculate
Www.theswimtimeonline.com
May 26, 2011 | Hayward SAND FILTER, PRO SERIES
My pump is on filter but is draining the water out please help
The water Has to be going out the 'backwash' or 'waste' line.Either that or you have a leak in the plumbing. If the backwash/waste valve is set in the 'filter' position and there is still water escaping through the backwash/waste line, it means that the o-ring or spider gasket needs to be replaced or re-seated. If it is a multi-port valve (one that you spin to select the setting as opposed to a 'push/pull valve) you can try shutting off the pump; do a complete turn, 360 degrees, from the 'filter' setting all the way back to the 'filter' setting. This sometimes helps the spider gasket re-seat
Nov 27, 2010 | Intex Wet Set 300 GPH Swimming Pool Filter...
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward pool motor shuts off in backwash mode.
Check the pump suction filter? To backwash it, is to
open the backwash tank cleanout valve, to clear the dirt out. If this does not work, check the pipelines going to the backwash tank for clogged lines.
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Mar 01, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
802 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
