Question about Sharp AR-C160 Color Copier
Copier problem - service code F1-70
When I turn on power I get a call for service code F1-70
  • jean claude liloli Nov 15, 2011
    ma machine sharp ar c150 digital me donne un code f1-70, que dois-je faire pour enlever ce code
    Sniper:
  • 54 Answers
F1-70 is communication trouble between the machine and the sorter finisher. Check the cables connecting the copier and the finisher and power off and on machine. Should clear the code. If problem persists, may need a new board.
I would also check the ground between the copier and finisher.
Don't forget to rate your answers, please!
Posted on Jun 08, 2008
Need the service code to enter service mode.
How to set up the service mode:
Service mode:
1. Turn the power on.
2. Press [MENU] button to display Setup menu.
3. Select "Features".
4. Select "Current Software Info".
5. Press [0], [6], [2], [5], [9], [6] and [Info] buttons on
the remote control unit in this order. The following
screen appears.
Code :
Pic code :
M I P S :
Press "POWER" key to exit.
Push 0key
Tuner :
S a f e t y :
safety_Non
Dec 11, 2013 | Canon NP 6035 Copier
Service code 542
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Sep 30, 2013 | Ricoh Aficio 450 Copier
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
Error code appear my Canon Xerox 405 e.i. e002. Please reply me how to solve the problem step by step. Please reply as early as possible. Thanks, Rajes Acharya
n Detail Code
To enter the service mode:
1) Press the asterisk key ' ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' ' on the control panel
Hope that helps!
PS If not you have problem in fixing unit, probably the fixing thermistor and need to be replaced.
Jun 24, 2011 | Canon imageRUNNER 400S Copier
I have a 2045e copier that I moved from one area to another. Now it gets error code SC545. How do I clear the code.
Press 'Function Clear' button, then '1' then '0' then '7' then press and hold 'Stop/Clear' button. The display will change to 'SP' mode. Now shut off the main power switch on the left side....wait 5 seconds with power off. Turn machine back on. If the code reapears, your Fuser Unit needs serviced.
Nov 13, 2009 | Ricoh Aficio 450 Copier
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
Jan 15, 2009 | Ricoh FT3713 Copier
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
After power outage we get a service code
The service code is probably "loss of Power" error.
One thing you might try is getting a battery back up that is rated for a copier machine.
This way if the power goes out the battery back up would keep power going to the machine preventing the error code.
FYI... the battery back ups are NOT made for copiers. You need on that is rated to back up a regular copy machine.
Hope this helps a bit.
Good luck.
Have a good day.
Mac =)
Apr 04, 2008 | Canon imageRUNNER 5570 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Sharp AR-C160 Color Copier Logo
109 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
