Question about Sony RDR-HX715 DVD Recorder
How to format new hard drive? - Sony RDR-HX715 DVD Recorder
How I can format muy new hard drive in Windows 7
Hi, you should not need to format your new hard drive, they arrive ready to use. If you require the format just plug you device in, go to hard drives where there is an option to format or repair
Jul 04, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Trying to upgrade my hard drive to 250gb. PS3 will not recognise new hard drive even after I format it to FAT32 on a computer. When I put new hard drive into the PS3 it tells me to format hard drive and if...
If your PS3 is telling you to format your hard drive, then it is recognizing it. You have to reformat the hard drive using the PS3, not your computer. If you don't have the option of formatting your hard drive then you may have to download an update from Sony and then run that disc to format the hard drive. Some of the updates will completely erase all saves, downloads, & etc when done from a disc. So be sure to use this with your new hard drive in the PS3, just to be sure not to lose all your stuff on your old hard drive. Sony has a "walk-thru" on these things on their website.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
Just installed new hard drive and it will not let me format or partition
Try one more new hard drive in the system and make sure the cables are nice and snug and connected.
If you can't format another new hard drive then that means its a problem with the main board. If you can format another new hard drive then that means the original new hard drive is bad from the box.
May 17, 2010 | Sony Playstation 3 (PS3) Console
I have recently attached a seagate hard disk with my pc already have a sata . the 2nd one is not detecting, help me
You have to initialize and format a drive before you can use it. A brand new unformatted OEM hard drive and installed it in my Windows Vista PC. The drive is connected to the motherboard via a SATA (serial ATA) cable, just like my original hard drive. This new drive was for data/backup. When I turned on the computer, the BIOS picked it right up. However, when I got into Vista, it did not detect any new hardware. I even went into the Control Panel and chose Add Hardware and let it scan for changes, but it didn’t find anything new. Windows Plug and Play If your drive isn't detected, there is no need to panic. Windows Vista is a little funny about this sort of thing, but it is quite easy to fix. The problem is that the drive is not initialized, so the standard plug-and-play procedure for adding a drive does not apply. First, you must initialize the drive, then it will allow you to format it. After the drive has been formatted, it will be ready to use.
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds. Your hard drive is now ready to be formatted. Formatting Your Drive Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Read more: http://www.brighthub.com/computing/hardware/articles/22069.aspx#ixzz0iPADjMwO
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a new, just out-of-the-box Seagate FreeAgent/Desk 1Tb external. After hooking it up, it just flashing and thats all. The automatic software installer did not launch and the Windows Hardware...
Dec 24, 2009 | Seagate Computers & Internet
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
How do you format the hard drive?
I have set up a dozen or so if these units.... so it's fairly simple (if you understand the terminology) - By the way, I just got off the phone with Samsung tech support to confirm. John at GVI /Samsung says the drive cannot exced 160 Gig or it will not recognize it period. Secondly, the drive cannot have any format or partition whatsoever. So use a partition tool and delete the partition and the DVR will initialize it and format the drive to suit it's operating system.
I have had luck repartitioning the drives in a basic FAT 32 and making sure I did NOT set the partition as active..and the DVR configured the drive properly. Good Luck!
May 12, 2009 | Samsung SSC DVR Digital Video Recorder...
New cruzers will not accept files
Please format the drive first then it will work when first time it is working with pen drive are ant hard drive you should format the drive then try to copy the files with NTFS are FAT formats
Jul 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to recover formatted data
Formatting a drive only resets the FAT (File Allocation Table), where it stores the information about the files on the drive. You need to get a utility that can read the data directly from the drive, bypassing the allocation tables. There are many available, most are not free.
Try going to TuCows.com, they are sure to have the utility you need. Be sure not to write any new files to the drive and you should have no problem in recovering your data. Search for: Formatted Drive Recovery
Mar 20, 2008 | Computers & Internet
Hard drive installation
You need to format the drive first before you can use it. If you are using windows xp, right click on the drive E and then click on Format. You can put a check mark on the box next to quick format if you like it faster and then click on start.
Please leave me a comment after you did what I said.
Feb 23, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
