Question about Ovens
Oven lights but will not heat up - Ovens
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Sep 17, 2010
No lights on oven, fan working no heat
No heat and fan working usually means the heating element has failed. Before you go down that road get the oven light checked as well in case there is a central problem. If by no oven light you mean the internal oven light is not on then that is just a bulb replacement. Make sure you get a heat resistant or original spec one though.
Jun 02, 2015 | Ovens
The oven will not heat. The stove, oven light work fine. Just that the oven will not heat.
Probable cause of that is an open heater - no connectivity. As you know the heater is the one that produce heat in the oven. So when it has a problem even when the light oven light up, expect there be no heating happening. Also the wiring that connected to it.
I hope my advice give you an idea.
Mar 23, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Elan 948 OVen doesn't heat and light designating heating does not go on.
we just had the same problem with the same oven. pull the oven out of the wall. on the top right side there is a fan. there is a safety switch that is activated by the fan blowing on it. a piece of insulation was preventing the switch from activating so the oven thought the fan was not running. remove the insulation and the oven comes back to life.
Oct 22, 2007 | Elan E-948-CB / E-948-CW Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
