Question about GE JVM3670 Microwave Oven
I have a micro wave oven that is arcing at the high voltage transformer when the cook cycle is turned on. the main fuse does not blow.The diode and the capacitor checks out ok.Is it the magnetron or the high voltage transformer that is causing the problem.
  • 1 more comment
  • b_ito Sep 17, 2010
    If I apply 120 vac to the primary of the high voltage transformer I do not get any arcing.With nothing hooked to the secondary the transformer has no arcing.
    Is it the transformer or the magnetron hooked up that is causing the arcing.
    first of all my problem was with a Kitchen aid model micro wave oven model
    # ykhms105ewh-0 and not a GE model
    If the high voltage transformer is acring under load,is it the transformer or the magnetron causing the problem.If I apply power to the transformer with no load there is no arcing.When I hook up the magnetron there is arcing at the transformer from the secondary to the core of the transformer.Is it possible that there is no arc when there is no load as this type fo transformer has no voltage unless it is hooked up.
    Could I used a smaller transformer from another microwave oven in this circuit to test to see if it is the magnetron causing the problem?
  • b_ito Sep 18, 2010
    The arcing starts with the cook cycle.I do not leave it on as it smells and makes noiseand also there is something wrong so shut it off.
    The transformer checks out ok with the ohm meter as being good.The magnetron also checks out as good with the ohms meter.The high voltage capacitor and diode check out ok.
    My feeling is that the insulation in the transformer is broken down and it is arcing when the high voltage is developed through diode & capacitor.
    I have tested the transformer with out being in the microwave oven circuit by appling 120 vac to the primary and it doesn't arc but in the circuit it does.
    Is there a possibility that the magnetron in causing the transformer to arc.
    I just don't want to buy the wrong patr to get the oven going again.
    also who sells cheap parts
    Thanks
    Bill
  • GE Master
  • 43,501 Answers
With the arcing being at the high voltage transformer and it still working otherwise I would say that the high voltage transformer is bad....
Typically the microwave will not work at all if the magnetron fails...
heatman101
Posted on Sep 18, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 18, 2010
    I think you are on the right track and yes it is scary going to buy parts, when you don't know for sure what the exact problem is...but I too feel that if the magnetron was not working then the transformer would have no load and would not be arcing...
    as far as parts go... here is a tip I wrote about buying parts online...
    How to Buy Appliance Parts Onlinehttp://www.fixya.com/support/r3907570-bu...
    heatman101
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to have an indepth knowledge regarding your query :-
http://www.kronjaeger.com/hv/hv/src/mot/index.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 17, 2010
My oven is working but the item inside is not heating. If I put 2 minutes, the oven wprks for 2 minutes, but the item inside is as it is without slight heating
It's very likely the high voltage fuse has blown, often because there's a fault in the cook section, or the fuse has metal fatigue. It will be in a thick plastic tube near the transformer and cook capacitor. Turn the oven off and unplug it for 10 mins, then take the cover off. As a precaution, short out the cook capacitor with a screwdriver. The capacitor is near the transformer, usually an oval shaped can. If it's not fuse fatigue, it can be: faulty capacitor (unlikely); faulty protection diode across capacitor, if there is one (very likely, must be replaced same way round as original); faulty rectifier diode from capacitor to chassis (less likely) or a magnetron heater that is leaky to chassis. All these things need to be disconnected, and tested one by one with a 500V insulation tester, because an ohmmeter will often not show faults in high voltage parts. Any leakage at 2200V will blow a fuse. If there's no high voltage fuse, it will blow the mains fuse inside, then nothing will work, but it's not that with yours, since it partly works. The oven can run without the high voltage fuse, just replace it with a wire with nice thick insulation, or with some plastic tubing over it. Anything else that's faulty must be replaced. I get my parts from WES Components at Ashfield in Sydney. Microwave parts in the cook section have high voltage ratings, and must be replaced with at least equal rating components. I just fixed a Samsung microwave with its high voltage cook fuse blown. The rest was ok, so I'd say the fuse wire inside had metal fatigue. I also always put a drop of light oil on both ends of the fan shaft, it runs quieter and faster then.
If the fault happened suddenly, it will be one of the above faults. If the oven is very old, it will have a gradually increasing cook time, as the magnetron wears out. If the cooking time is too long, replace the magnetron, they're only held in with 4 screws or nuts. It must be the same physical fit and at least the same power rating as the oven's rated output power.
Feb 25, 2016 | Sanyo Microwave Ovens
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Model 721.64282 microwave/convection oven - microwave not heating and making a loud noise. convection oven works
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Oct 21, 2010 | Kenmore 63663 Microwave Oven
Not heating
Remove the outer cover (pull the power plug first) and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan-like device located within the sheet metal wave-guide near the opening in the cooking cavity where the microwaves come into it). This stirrer has a plastic bearing that frequently arcs over and permanently shorts out the microwaves which blows the fuse. If no blown fuse is found, look for a loose or defective door-interlock micro-switch.
Nov 17, 2009 | Kenmore 61652 Microwave Oven
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM3670 Microwave Oven Logo
61 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
