Question about Kenmore 22422 Top Load Washer
Aggitation problems my Kenmore model 70 just started blowing the circuit breaker when it is aggitating, it started out only doing it on fast , now it is doing it on all speeds of aggitation. It is pulling too much power while doing this, like it is in a bind. What do I need to check to get this fixed. Everything else works fine, it spins fine, and drains the water fine also
  • rocknrobbin May 21, 2008
    after getting some advice from a local repairman I replaced the motor yesterday. everything is working fine now. Thank you for your help
Same problem...any luck yet?
Posted on Aug 08, 2008
  • 868 Answers
Replace the motor.
Posted on May 20, 2008
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
Just purchased used a Kenmore stacked washer/dryer: tub spins during aggitation cycle. So my clothes are spinning around in water but not being aggitated. Now Im aggitated!! Grr!! How much will it cost...
Sounds like the plastic spacer between the transmission and the tub has broke. Part is no more than 5-10 bucks. Labor, not sure. Did you buy the warranty....I think you still have time to buy it if it's new... But I think Kenmore may guarantee for 30 days but you may want to call where you bought it from new.
Dec 14, 2017 | Kenmore Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
I have a model 70 kenmore washer that will not spin or aggitate.
Captain we have a problem with the hyper drive. Spock what do you make of it? Logically speaking I would say we is dead in the water. Bones what do you make of it? **** Jim I'm a doctor not a laundry attendant. Scotty give us an update: Aye captain the lid switch has failed. if we don't do something fast the funk will knock us all to our knees in the laundry room. What do you suggest Scotty? I say we take a look at the lid switch Captain. 8f7d82e.jpgLogically captain we should check out this excellent page on clutch replacement which includes directions how to jump out the lid switch FOR TEST PURPOSES ONLY. Proceed Spock...and may the farce be with ye
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Aggitator operates as soon as the washer is turned on.
Your pressure switch hose maybe be plugged. This is happening because your washer thinks it's full of water.
Remove the clear hose from the pressure switch behind the control panel and blow through the hose. You are basically going to blowing air through the hose and into the wash tub. This will clear any restriction that is in the hose.
This is a common problem and a simple fix for your issue.
If you have anymore questions about this please ask. I will be more than happy to help you further.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 22422 Top Load Washer Logo
194 people viewed this question
Sal De
 Brian Main
Brian Main
