SOURCE: samsung p1253
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
SOURCE: samsung washing machine
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine
Go here for a new filter. If the link does not work, go to the repairclinic website first.
SOURCE: drainage wont work on samsung p1253 washing
could need a new pump. could be something jammed in pump
SOURCE: Letters UE on display
UE = Unbalance Error
Laundry load is
unbalanced, manually loosen any tangled laundry.
If only one item of
clothing needs washing, such as a bathrobe or jeans, the final spin
result might be unsatisfactory and an UE error message will be shown
in the display. Unbalance error is cleared by POWER switch OFF and
back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: hi,i have a samsung washing
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
