Question about Dell Inspiron E1505 Notebook
Sound is scratchy even when hooked to other speakers
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Oct 04, 2010
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
Dec 14, 2017 | Zenith Z50P3 50 in. Plasma TV
I was given the amp and I want to test it with a volt meter to see if it even works. I currently dont have a system .
Easiest way, get any old speaker 4 or 8 ohm and hook it up to channel 1 then plug an rca lead into channel 1, power up amp and touch finger on rca and you should hear pop or scratchy sound from speaker . Audio circuit for channel 1 is good . repeat for channels 2 3 4 .
Mar 17, 2010 | Eclipse PA5422 Car Audio Amplifier
The speakers are making a very scratchy noise. They are hooked up to my desktop computer. When first purchased last year, they sounded quite good. Now, they are very scratchy and not on high volume.
Do you by any chance have any other wireless device like a cell phone near the speakers when you hear this?
Any kind of device that has a magnet field will cause scratching sounds on the speakers. I discovered this quite by accident with my old Boost mobile phone.
Debbie Mahler
MICE Training, Technology & Education
mice.org
Oct 24, 2009 | Bose Companion 2 Series II Multimedia...
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
DURABRAND 2.0 CH USB COMPUTER SPEAKERS
try going to control panel, the system icon, hardware tab, divice manager, check to see if your sound card does not have a yellow ! icon next to it, if it does try right click, go to properties, and reinstalling it, it does help if the computer is hooked to the internet so it can find it automaticly over the internet.
Aug 29, 2008 | Durabrand 5.1 Surround Sound Computer...
Sound is distorted
Good Day;
Suspect the audio output IC. If you are using the TV's speakers.
Good Luck, big IRISH.
Aug 22, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Laptop sound distort / scratchy
have you tried connect external speakers and see what happens ?
Mar 30, 2008 | Sony VAIO VGN-N130G/W Notebook
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
Dell Inspiron E1505 Notebook Logo
83 people viewed this question
Alun Cox
