Question about Mercury P4VM800M7 Motherboard
Disconnected the power supply for mercury motherboard but now it powers but the hard disk doesnt power nor does the screen show anything its just on what might be the problem???? please help
  • Mercury Master
  • 27,725 Answers
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 17, 2010
My Toshiba tecra a7 laptop does not start,when you power on led indicater blinks 10 times and goes off . It was working perfectly allright one week ago and did not use it for one week.power supply is
Back up a little bit and tell us if the screen shows anything at all. If it does not coupled with the lights that are flashing, you have a loose cpu or the cpu is bad.
Feb 05, 2015 | Toshiba Tecra A7 Series Laptop System...
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
Will not boot up screen remains black
hi,
  • Check the VGA connections to ensure its well connected.
  • Disconnect everything from power completely.
  • Remove the CMOS battery and disconnect the hard disk's power supply.
  • Leave it as such for a few minutes and then connect everything from scratch including the CMOS battery and the hard disk.
  • Now run the boot set up.
thanks!
Sep 25, 2011 | MSI 880GMP51 AM3 AMD 880G Micro ATX AMD...
Screen shows "Reboot and select
what you want do is disconnect your hard drive then disconnect the power from your motherboard the from the power supply, and press the power button the connect all the power cables back then enter bios screen go to the boot tab and select boot device priority and move your hard drive up.
May 21, 2011 | Computers & Internet
I have a Dell XPS M170 Laptop. The screen went totally blank in the middle of an application. Now on reboot nothing comes up. The led lights won't light up the and screen remains blank. The power light...
Take out your ram sticks and put them back in. Also disconnect your hard drive and reconnect it. Then restart. If this doesnt help you may have a blown power supply.
Mar 20, 2011 | Dell Inspiron XPS M170 Motherboard - F8453...
Computer is dead. When I press the on button, nothing happens. It is plugged in. I opened it up and saw a green LED on.
It is entirely possible that your power supply has died. FYI, I just got a similar computer in the shop. Same symptoms. Turned out the power supply had failed and it also blew out the motherboard. Hope that yours is just the power supply!
Oct 06, 2010 | E-Machines T2893 PC Desktop
Is motherboard kaput?
are you german tink so
i think you can not go to windos. then *********** board bios might be at wrong way
(this is not the case in 99% i say)
try bios cnfiger .
in this msasage you gat onley about ide secendary then ide primary mightr be working try set ahard to it and set the bios primery boot driver it
this dosent work neer the cmos tou well see a jumper known as cmos_JP,cmos_J put the jumper to the other way and torn on torn off put it back it where restart
this might work if not
Most dafaneetly you mather board is Kaput
Jun 09, 2009 | Mercury KVM266PM-U (KVM266PMUD1600)...
Computer stays on bios page
Hello there
first i would remove the battery on the board and see if it is good if so replace it and now remove the power supply to the motherboard for 2 min and press the power on button and the reset button
now plug in the power supply to the motherboard back on and plug in the computer now you should just have top reset the time and date ok?
best regards michael
Apr 05, 2009 | Compaq Digital PC 3100 PC Desktop
Power surges in the last couple of mornings. the other day power went off and on four or five times quickly. now my compaq sr5250nx will only show compaq start page and will not do anything else
Power surges affect hard disks very badly. So please disconnect hard disk and see if your are getting some messages on the screen. if so replace hard disk.
Dec 20, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
41 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
