Question about Kenmore 44042 Front Load Washer
Washer will only wash with hot water. I'm no expert but it sounds like only the hot water hose is hooked up....what do you think?
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
When my Kenmore machine is running on the wash cycle warm/warm no water is coming at all. I could run the machine only with cold water even on the cycle warm/cold.
Most likely the hot water hose is plugged up, or least likely, the hot/cold valve is broken or plugged up.
Find a large container, or better yet, hook up a garden hose that you might try the faucet where the hot water is hooked up and see if water will come out of it when the washer hose is not hooked up there.
If it will not, you have a plugged up hot water pipe or the water heater shut off valve is closed.
If you get good water pressure and hot water from the faucet, look at the filter screens that are inside the ends of the hot water hose and see if any are plugged up.
There may be several.
If not, perhaps the inlet water solenoid has failed. That plastic part is where the hoses attach to the washer itself.
God bless your efforts.
Jan 22, 2016 | Kenmore Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a really old maytag A606 washer. There is a terrible knocking sound when i try to fill the washer with cold water. I switched the dial to a hot wash, and it works perfectly. Do i need to replace the...
Have you taken the hoses off and checked to see if there is a screen in the hoses?............or on the machine itself its a longshot but usually there are little mesh screen filters either in the hoses or on the machine itself. If its knocking its either dry (no water) or the solenoid is going bad.
Cheap fix possibilty get a Y connector hose and you can mix your hot and cold water in there then just feed it through the hot water side. Or just hook your cold water hose up to the hot water side and just wash with cold water. If you are looking to just get it running and save money.
A couple thoughts anyways
Aug 23, 2013 | Maytag SAV4655A Top Load Washer
Always uses the hot water and not cold or warm water. cold water is on washer just uses the hot watere
Sounds like the hoses are hooked up opposite. Swap the hose connections on the washer.
Nov 01, 2012 | Washing Machines
My washer won't fill up what is the problem?
Hot and cold tap water valves not turned on.
Bad water inlet valve.
Bad control or temperature selector switch.
The water level sensor is bad.
Or you could have only the cold water hose hooked up and selecting hot wash only. Or you have the hot hose hooked up only and selecting cold wash only. Try selecting a warm wash and see if you get cold or hot water only. If you do, you'll know which is missing.
Jul 28, 2009 | Whirlpool Washing Machines
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Mar 01, 2007 | GE WHRE5260E Top Load Washer
Kenmore 44042 Front Load Washer Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
