Question about Canon PIXMA MX310 All-In-One Printer
My canon mx310 won't print images. when i print it just feeds paper through but does not put the image on the paper.
Ajkill
  • 2035 Answers
SOURCE: printing a banner via canon mx310
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
and select printing banner and then apply ok then start printing
Posted on Oct 12, 2008
yooperbud
  • 8637 Answers
SOURCE: canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
dmbgo
  • 58 Answers
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Posted on Jun 21, 2009
sitehr
  • 94 Answers
SOURCE: D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Posted on Jul 22, 2009
pineworks
  • 4041 Answers
SOURCE: how do i get my canon mx310 to print mirror image
Hi there you goto get yourself a program on your pc there are lots of them on the net art program photo and so on one I like is the paitshop pro it can do all that you can also get some programs for what you need T Shirt program and you need the right transfer paper for it, Also a good printing program is on the net free to download it called PagePlues SE this I think you will like you can add all sorts of back grounds and so on.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
My Canon MX310 printer is not printing. The paper feeder is not feeding the paper into the printer. It is feeding only on one side. We are unable to print or get faxes. Can you help me out?
It seems like there are some problem with roller inside..
If you have an air gun, try to get ride of dust as much as u can.
Or if you do not have one, ple use vaccuum cleaner...(at min. power) to **** out dust.
And then try for it.
Apr 08, 2011 | Canon PIXMA MX310 All-In-One Printer
When I try to print it starts a sheet of paper then lets go of it before it prints then says paper jammed when it has failed to load a piece. I have a pixma mx310
Clean the pick-up mechanism and feed wheels with isopropil alcohol and a Q tip. These items are probably slick and not gripping the paper.
Jan 24, 2011 | Canon PIXMA MX310 All-In-One Printer
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
136 people viewed this question
old marine
old marine
