Question about Fargo DTC550 Thermal Card Printer
FARGO PRINT HEADS
I too am getting a white line.i dont see a nick on the print head and no debris.is it possible to wetsand the head ? suppose if its a connection not getting voltage there would be more than a line,im at knaves1st@hotmail.com.thank you
  • Anonymous Sep 09, 2008
    card comes out with a white line
    Problem Solver:
  • 6 Answers
If you have a solid white line running the entire length of the card (think landscape style) you probably have a bad print head. I always tell people if you could place a ruler along the line and it is perfectly straight along the ruler, then that is a classic example of a bad print head. Check the MFG warranty for replacement or purchase.
Posted on Apr 16, 2009
Printing is not clear some long white lines
This sounds like you are running low on ink, your print heads are clogged or are out of alignment. I would buy a new All-in-One because of the low cost of new ones these days but if you want to make this one work try using the printer software and find clean print heads and/or align print heads. If that doesn't work try new ink. Good Luck!
Jun 06, 2014 | Panasonic KX-MB2010 All-In-One Laser...
Tip
Horizontal Lines on your print out paper
Possible Cause:
Air in the print head: This is the most common cause of printing problems. When changing the cartridges, or for other reasons, air bubbles can enter the print head. This prevents the necessary pressure build up (through heating or vibration) as a result, no ink is sprayed onto the paper and you can see white lines. This effect is also called banding.
Solution:
To improve your print, most printers feature a print head cleaning cycle. Ink is flushed through the print head to re-establish the ink flow. It may be that you have to carry out this procedure several times to achieve the desired result.
Possible Cause:
Blocked nozzles: If the printer is not used for a long period, particles can build up and block the print head.
Solution:
To remove this blockage, run the cleaning cycle. If you cannot achieve a satisfactory result, use a nozzle cleaning fluid.
Possible Cause:
Defective print head: Print heads are exposed to high stress. The temperature variation in thermal print heads can vary by 100`s of degrees centigrade up to 10000 Hertz (10.000 times per second). Therefore print heads have a certain amount of wear and tear. Depending on the manufacturer and price, print heads have a limited life. Epson uses Piezo print heads, which guarantee a long life. However if they do become defective, compared to other printers, the repair can be costly.
Solution:
With printers that feature integrated print heads that are separate from the ink tank (that is for example, Epson and most Canon machines) all that remains is to change the print head. With HP Lexmark and Dell the print head is part of the cartridge, and is automatically replaced each time you replace the cartridge.
on Aug 29, 2010 | Office Equipment & Supplies
White lines on dark photo prints
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Oct 18, 2012 | Canon MP560 All-In-One InkJet Printer
I've got vertical lines down my photos
Usually happens when print heads have been damaged usually from inferior inks have print heads replaced if possible, If it is only happening with particular software try another printing program, If problem is present still either repair print heads if possible otherwise replace printer. I hope this helps
Aug 30, 2012 | Epson Stylus Sx400
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Fargo P C30
you probably have a scratch on the printhead.
Mar 14, 2009 | Fargo Persona C30 Thermal Card Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
White lines in print
Does the printer have replaceable printing heads, or are they integral to the ink cartridge. If so they may need replacing or calibration. Another issue may be electronic contacts, check inside the printer and on the cartridges for any dirt or debris on the (usually copper colour) contacts on either end.
Also, if possible try the printer on an alternate computer to ensure it is not a problem with your software.
Kind regards, ACD
Jun 10, 2008 | Office Equipment & Supplies
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
254 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
