Question about WYSE V90LE Thin Client VIA 1.2GHz, 1GB Flash/1GB RAM, PCMCI+SD, US, NIC, XPE Network Terminal
I can't start my wyse client, it has an orange collour on power led?
4 Suggested Answers
SOURCE: Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Posted on Apr 04, 2008
SOURCE: wyse 1200LE - error - out of frequency
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Posted on Apr 23, 2008
  • 25 Answers
SOURCE: start Wyse S90 takes a long time
Try updating the OS from the Wyse website (using WSI, the new USB imaging tool, or WDM). It might simply be that the current image is corrupt. 10 minutes is excessive. It should boot in under 2 minutes easily.
Posted on Jul 07, 2009
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Start Wyse S90 takes a long time
Apr 15, 2009 | WYSE S90 THIN CLIENT KB/MSE XPE...
WYSE S10 thin clients; we are hearing from users that when they hit the power button, the unit restarts instead. This behavior is also present using the gui interface. Not all units are doing this, but we...
Check in the BIOS, "Fireport" is the password. I cant remember if the power button behavior is set there or in the wnos.ini file.
You can check the config generator on technicalhelp.de to see if the command is in there for the wnos.ini
Apr 07, 2009 | WYSE S10 (90210501) Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
Reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
Dec 08, 2007 | WYSE Winterm S30 Network Terminal
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
WYSE V90LE Thin Client VIA 1.2GHz, 1GB Flash/1GB RAM, PCMCI+SD, US, NIC, XPE  Network Terminal Logo
138 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
