Question about Blaupunkt CDC-A08 10-Disc CD Changer
Blaupunkt CDC-A08 eject button broke off
I've had this cd changer since 99. I left the door open and something hit the eject button and broke it off. Since I've had it such a long time I don't have a problem opening up the case to see if I can replace the switch. I've done some electronics in college, mechcanial engineer with a bit of circuit building experience. thx
4 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Posted on Apr 15, 2008
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Posted on Mar 23, 2009
SOURCE: Pinout of Round Connector on CDC A08 ?
See this diagram.
http://fileshare.eshop.bg/index.php?what=search2
(search for CDC A08 if link doesn't work)
Basically, 12v to pin '3' (with notch at top, it's the top row, third pin from the RIGHT) and ground to outter jacket of the connector. Push eject button, works a charm.
Cheers.
Posted on May 06, 2009
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Dear Sirs, i have the cd changer balupunkt cd-changer a08 working however whenever i put new cd it doesnt play it only says cd error i have tried several ways of making the cd windows media player, nero...
Plays some does not play others. Soon nothing will be playable. Laser assembly losing ability to focus properly on disc surface and it has to be replaced since repair is not cost effective with these things.
Aug 31, 2017 | Blaupunkt CDC-A08 10-Disc CD Changer
CD changer skips on bumps
There are two ways either the 90* or the 180*. If your having problems like skipping I'd suggest finding a place at the center of the car where there is less shock for the unit, like under your seat. I know changers have this 6 seconds or more memory so in case it skips, the first 6 sec ahead of the song is stored and play it to avoid the skip.
Oct 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
2002 Explorer indash cd changer malfunction 'cd error'
its an optical problem, you may try cleaning the lens or try replacing a new one.
Jul 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
See this diagram.
Cheers.
Mar 27, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Blaupunkt CDC-A08 10-Disc CD Changer Logo
82 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
