Question about Dell Latitude D510 Notebook
Easy Question : New to game, have D510 using Netgear "G" can this be converted to "N" or new "R" drive with minimal cost and effort. Thank you for your time. Thor
  • Dell Master
  • 11,800 Answers
No. It's a hardware limitation, if you need N then you need N supported hardware/router, and you will need to also change the wireless card from the pc to which you will try to connect to an N compatible one.
Posted on Sep 17, 2010
Brand new TBTS, done 15 kilometres, but has a metallic sound when i apply 1st gear.
All bullets as brand new, requires more effort to switch the gears when compared to other bikes. All sounds will be minimized after 3000 kms or You will get used to.But not to worry
May 28, 2011 | 2011 Enfield Thunderbird TwinSpark
I have an xbox 360 model #1439. My daughter was playing nearby and was appently too close to the drawer sensor. The drawer opened and she accidentally kicked it as she got up. The must have been knocked...
DVD drive doors are not really made with repairs in mind. The cost of the repair would be far more expensive than replacing the entire drive. The time it would take your local Xbox to take your unit apart enough to remove and replace the drive is relatively minimal, and the cost of a new drive should not exceed $40-70.00, plus no more than an hour or two of labor cost. Just to be on the safe side, contact your local Xbox repair center and have them give you a quote on the replacement. Then check the cost of replacing the unit. Depending on the shop's labor charge, it may be cheaper to just replace the unit. The Xbox just dropped in price a few weeks ago.
I hope this information will help. Thank you for using our service.
Mar 21, 2011 | Microsoft Xbox 360 Console
My xbox 360 won't read my video games
This is quite a common problem and it is actually caused byt the heat on the back of the drive.
To fix it you need to stop the heat and you can send it in to do this or you can use a good Xbox 360 Repair guide from home.
I hope this helps and if so can you please rate so it can help others?
Feb 22, 2011 | Microsoft Xbox 360 Console
I buy a new game and my 360 wont play it.
Well you probably know what the problem is.
Your drive either has a weak laser , which is easy to
install yourself and cost around 20.00-30.00.
Or the spindle motor or worm gear motor is failing .
This will require you to buy a new drive and swap
the P.C. board for your old drive to the new one
The cost of a new/used drive is around 40.00 on
ebay . this is a sure fire way to fix your drive problem.
If you have any questions feel free to ask.
Rob
Sep 02, 2010 | Microsoft Xbox 360 Console
What happens when my xbox 360 arcade wont play any 360 games? My xbox 360 arcade will not play any of my 360 games. The disc are brand new. I bought the xbox 360 arcade used.
Find someone in your local area that can adjust the laser power level on the DVD drive. This is a temporary solution. A better solution is to buy a new drive off of ebay that is the same one that you have and change the PCB boards so you have the same PCB board in the new case with everything else. To see what drive you have, take the face plate off of the console. Look at the front of the DVD drive and there is a small hole on the lower right hand side of the drive. Look at the two wires inside the hole. Red and Black are a Samsung drive, White are a Lite-on drive, yellow are a Benq and a black plug is a hitichi.
This is very easy and only requires minimal soldering.
I have an old ps3 (bulky console) i put games in, loading icon is spinning but when it stops the game icon is not showing to play the game. help!!!!
This is a very common problem for the older PS3's. Basically what has happened is your blu ray drive laser has become faulty. Unfortunately the only real solution is to either buy a new drive or a new laser. If you do decide to buy a drive and fit it yourself you will need to keep the large circuit board that is screwed onto your blu ray drive as it is needed by the motherboard of your PS3. The drives themselves are very easy to fit but if you need any more help just let me know.
Thank you for using FixYa
Aug 11, 2010 | Sony Playstation 3 (PS3) Console
Compaq Evo D510 tower: game compatibility issues
Upgrading the windows version and adding ram and better video card may be a good solution. It couldn' hurt at least.
Try it and see if you can play you games.
Games are the most resourse hungry application that you can put your computer through. The ram size and video card memory size are critical for acceptable preformance.
Thank you and good luck,
James.
IF THIS WAS HELPFUL, PLEASE VOTE 4 THUMBS!
Apr 25, 2010 | Compaq Evo D510 Minitower (Open Box)...
Xbox 360 will not read games
its the drive or the laser.
the laser is easy to replace cost 20.00 D.Y.I
the drive will need to have the board swaped
in to a new drive cost 40.00 D.Y.I ,
Jun 13, 2009 | Microsoft Xbox 360 Console
Compaq D51S/P2 can somebody help me drives for this ?
Drivers for this model can be found below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=97129&taskId=135&prodTypeId=12454&prodSeriesId=96300&lang=en&cc=us
Compaq Evo D510 Models with Intel 845G Chipset All D510's come with: Integrated Intel Extreme graphics Integrated Intel PRO/100 VM NIC Integrated Intel PRO/100 VE NIC (e-pc only) Integrated Intel Audio Model Key
Example: D5S/P1.5/20j/2/128c/vn
D51S
D510 Small Form Factor
D51C
D510 Convertible Minitower
D51U
D510 Ultra-Slim Desktop D51E
D510 e-pc P2.0
P4 2.0Ghz processor (c = Celeron) 20
20-GB hard drive K
XP Professional X
XP Home P
XP Pro/2K dual install 2
Win 2K 256
Memory amount
C
CD ROM
R CD-RW
N NIC
Jan 27, 2009 | Computers & Internet
My xbox wont play any of my game
does it say there may be a problem with the disc may be dirty or damaged? If so this usually means the dvd drive is getting weak. Its a easy fix though and cost around 30 to 40 to get a new drive for it.
Jan 07, 2009 | Microsoft Xbox Console
Dell Latitude D510 Notebook Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
