Question about Panasonic KX-TD7895 Cordless Phone
Panasonic KX-TD7895 wireless phone displays: “Need Repair 1” I have experience fixing phones and working on electrical components on circuit boards. What do I need to do to repair this phone? I have the transmitting base, as well.
  • Panasonic Master
  • 12,061 Answers
Hi. well the first thing you must have is a service manual, Below, below that is your user manual, BOTH are important
http://www.givemefile.net/smanuals/telephones/panasonic/kxtd7895.html
http://www.retrevo.com/support/Panasonic-KX-TD7895-Telephones-manual/id/2920ci461/t/2/
Then you most likely need a Multimeter, a toolkit, (small screwdrivers, cutters. etc.)
One thing to always check, is the battery this causes almost 75% of all problems are battery related.
make sure power is OK, then work through the service manual troubleshooting steps to isolate your exact issue.
Check crystal activity, another problem, check all connections. Check Coding, try resetting the base and handset. try recoding too.
Posted on Sep 18, 2010
Where is my handset?
if the handset is out of battery I'd keep looking. The panasonic KX does not have an emergency battery reserve for finding the phone
Jan 22, 2018 | Panasonic KX-TD7896 Cordless Phone
Panasonic KX TG2237 - Handset lights up but displays message "no connection to base unit"
Unplugged and reinstalled all components. In the process I discovered a GFI circuit had tripped. When I reset the circuit breaker all was well. Problem solved.
Jan 06, 2010 | Panasonic KX TG2237 Cordless Phone...
Panasonic KX-TG5631 that works but no display
This problem can have many solutions as it can have many origins. But one of them, and it seems the problem is synchronized, happening to several handsets within a short period of time, as if they ran out of their useful life all together, is caused by the breakage of the flat cable connecting the display to the main board. The thin film conducting material deposited on the plastic base wears off or breaks just close to the display driver making it impossible for the video signals to reach the LCD.
A solution I found was to file part of the white plastic display support base to give the flat cable some slack, and them to insert a rubber wedge between the support and the main board to keep some pressure on the cable, lifting it up a bit, bending the cable as to make the film cracks close and remake electrical contact.
It is not a permanent fix (replacing the display would be) but the phones can go back to normal operation for some time. How long? I don't know yet.
Dec 18, 2009 | Panasonic KX-TG5631 Cordless Phone
I have a Panasonic KX-TD7895 cordless phone. The volume is so low that I often can't hear the conversation. Hitting the volume button does not resolve the problem. Any ideas on how to fix this?
Common problem, but if your not a phone tech with a parts account, schematics, etc.., I recommend you send it in for repair than risk breaking it since it is such a valuable phone and one wrong move can ruin it beyond repair. If it was a $50 phone, I would say tear into it and give it a shot. But at over $350 you should have a pro do it and its much cheaper than buying a replacement or sending to Panasonic. Google kx-td7895 repair and you can find a private facility.
Mar 04, 2009 | Panasonic KX-TD7895 Cordless Phone
Hello -need help with phone
Hi Nick,
There are no intensity adjustments I know of, and from my experience if the backlight is still working, but you get no display, it is either a bad display, or many times corrosion or a broken solder joint/component. I wish I could help you correct the problem with a few pushes of a button but not in this case. We do fix those models, you can check us out at www.cordlessrepair.com Thanks, CG
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Panasonic TD7895
Not to be the bearer of bad news, but I think they have to go back to the factory in GA to be synched again.
There might be something obscure in the codes on the handset and base that will let it work, but I'm guessing not.
Carl
Aug 28, 2008 | Panasonic KX-T7630 Corded Phone
KX-TD7895 problem
If you were using this unit and it was functioning, then most likely the handset has gotten damaged, and you would need to send the handset and base into repair (its not programming setting or a field servicable problem). If your testing this unit for the first time, the base may not "match" the handset. You can tell if they match by looking at the code on the little white sticker on the bottom of the base, and it must match the code on the sticker on the handset which is under the battery. So if they match, and they still will not communicate with eachother not much can be done until its put on a diagnostics and testing. You can google kx-td7895 repair to find a facility. Good luck
Apr 23, 2008 | Panasonic KX-TD7895 Cordless Phone
Panasonic KX-TD7895 Cordless Phone Logo
275 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
