Question about Ovens
I need a glass oven door for a SAMET oven. model 236 under counter oven & hob. I live in Centurion Gauteng South Africa. Please give me a price and where I can get it from.
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
  • 44 Answers
SOURCE: How to clean the inside of the glass door of Electrolux Wall Oven
Hi
open door and along top you will see 2 screws undo but hold door at same time then just lift out and clean.
hope this helps
Posted on Mar 21, 2009
ginko
  • 19396 Answers
SOURCE: broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
bozcro
  • 867 Answers
SOURCE: the inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Posted on Jun 27, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
The inside glass (between the inner and outer glass of the door) of the upper oven door of my GE JT952-30 shattered during a baking cycle. I need the replacement part number and a possible source.
Hello would need the entire model number as you can see by this link there are 32 models of that oven http://www.searspartsdirect.com/partsdirect/part-model/JT952?searchModPar=JT952&pathTaken=modelSearch&prst=0&shdMod=JT952
you can either message me back and I will then pick which is your unit then you would go under door schematic and it would bring up the diagram for your unit which when you clicked on door it would being you to this blown up view of the door this is an example http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Wall-oven-Parts/Model-JT952BF7BB/0432/0125300/G0510389/00005?blt=06&prst=&shdMod= and if you scrolled down to like on this schematic has the outer door glass shown as number 140 in the diagram and then underneath that it would give the part number such as it does for this one being
PART NUMBER: WB57T10259 if you have any further questions or would like me to look your model up further please message me back with the complete model number Thanks Rick
Jun 28, 2011 | GE Profile JT952 Electric Double Oven
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
KHO KIC KUCO600B 60cm BLACK Undercounter Oven and Hob set
south africa, or australia? get online to the manufacturers website and inquire!
good luck!
Oct 19, 2009 | Ovens
Loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Aug 07, 2009 | Whirlpool GBS307PR Electric Single Oven
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Jan 04, 2008 | Ovens
Ovens Logo
110 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
