Question about HP Compaq nx6110 PC Laptop
1781 Disk 1failure
I have an HP compaq nc6230 and every time I boot up it says 1781 Disk 1 failure. I'm running hdd test on the computer setup option. I wonder if this helps. P.S. I installed XP Pro because i didn't have its own original one.
Thank you for your help,
  • Anonymous Jun 25, 2008
    my laptop hp nc6220 swich on the laptop hp logo comminig after 1781 disk failure way
  • saintil32 Apr 29, 2009
Hi I have the same problem - when I turn on my compaq nc 6230 it says "1781 Disk 1failure ", I click enter button and it's starts to boot windows xp and works good without any poblems. I took the HDD out and install into different nc6230 and it works good and no any erro "1781 Disk 1 failure" at all - so it's NOT an HDD problem ! Can somebody help to troubleshoot ! Thanks.
Posted on Sep 15, 2008
Este problema no tiene solucion por medio de actualizacion alguna
Es un problema familiar para HP y la solucion que me brindaron fue el cambio de la placa madre asi que no pierdas el tiempo y contacta al sentro si es que se encuentra en garantia
Posted on Apr 16, 2009
  • 77 Answers
My suggestion
Back up your data and change the harddrive.
Your hdd is bound to fail anytime soon.
Posted on May 17, 2008
MY COMPUTER IS NOT BOOTING BECUASE IS NOT SEING THE HARD DISK WHAT CAN I DO?
if it is HDD problem them BIOS must says no boot device, if it is try to test HDD with Hierens Boot CD if cant help then replace HDD
Nov 13, 2012 | HP Compaq nc6230 Notebook
I have a HP Compaq nc 6230 which say 1781 HDD error and can not boot. i have done a BIOS test and everthing is fine but the problem keeps comming what can i do. pls help
HI rogerspie200 , actually problem is related to your Hard Disk Drive Bro not to BIOS and other hardware problem so please first of all check your Laptop Hard disk drive for whether it is working or not , if it is working then just format your pc
Jun 06, 2011 | HP Compaq nc6230 Notebook
When I turn laptop on it goes to sorry for
Try formatting a new version of Windows into the system if you don't have much to loose on it but you try this
switch off the system
remove the battery
press and hold the power button for 30 seconds
insert the battery without releasing the power button or plug directly to power source if putting the battery back will be hard for you
Then release the button and switch on the system
or google "how to clear black screen"
Jul 29, 2017 | Compaq Evo N410C Notebook
Have a gateway Mt3708 it started turning off on its own now I have no screen. I had gotten message reading as follows: YUKON Pxe V4.17.8.1 (alpa) (20060116) (C) copyright 2003-2006 Marvell (R) all rights...
when the logo comes on, press the "tab" key. It should turn the logo off and show you what the computer is doing. This may help:
THIS IS FOR HP AND COMPAQ USERS (it might help others as well)
i had the same problem with my compaq preasrio v6000.
ALL U HAVE TO DO IS
1- START UP UP UR COMPUTER AND PRESS F10
2-GO TO DIAGNOSTICS
3-RUN A HARD DISK TEST
IF IT PASSES THEN YOU JUST NEED TO RE-INSTALL TO YOUR OPERATING SYSTEM
IF NOT YOU WILL HAVE TO CHANGE YOUR HARD DISK.
Or try this:
Go into the BIOS.. Go into the BOOT options.. and hit Shift+1 to disable the Realtek boot option.. pop in the disk you want to boot from.. and make sure you set your boot options to CD-Rom and then HDD.. and just wait.. be patient.. and the blue screen (for booting) will show up! :)
Mar 15, 2010 | Computers & Internet
Compaq laptop nc6230 freezes on startup with XP SP3
hello
you reis goninstall your system factory setting and your problem e i advise to u use ur laptop very softly
you can give me high rating for this help
please
Oct 20, 2009 | HP Compaq nc6230 Notebook
Hi i forget my password bios hp nc6230 and the computer give me a message:Disk1 failure 1781 please you can help me?
Well... for the BIOS password, that's usually fairly easy. There is a jumper on most motherboards labeled CLRCMOS (some actually say CLR PASSword). Should be 3 pins, with a jumper set on 2 of them. move the jumper to the other side, press the power button. Nothing should happen, no fans or anything. then move the jumper back, and startup. Should clear out the password. As far as the disk failure- may have a bad hdd. download DFT, burn it, and run an advanced scan on your hard drive.
Apr 29, 2009 | Computers & Internet
1781 disk 1 failure
It could be the HD failing, the onboard controller failing (meaning the motherboard, or more importantly the laptop is toast), or it might simply be that the HD connection to the controller just needs to be reseated. The first thing to try is the HD test built into the BIOS. It should give a clearer idea of what is actually happening to the LT.
Dec 24, 2008 | HP Compaq nc6230 Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
1780 disk 0 failure message
it's hard drive...most likely you are in need of a tune up.
check out this link, and you may find the Tuneup is just what you need.
Mar 17, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
2,248 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
