Question about Hoover HDC7FM Dryer
Hi, I have a Hoover HDC7 FM UK tumble dryer. Problem: After seting timer, I press Start but the motor doesn't turn, I can here a "brrr..." noise comming from the motor. Everything works (heating, door switch...) but the motor. I opened the machine, took out the drum and press the start button again: - The motor just try to initiate a spin then stop, - The motor makes a light "brrr" noise, - The motor will not keep turning if I initiate it manually, - The motor offers almost no resistance if I turn it by hand (isn't it supposed to?). Questions: - Is it a capacitor problem? How can I check that? - Can it be a motor brush problem? Thanks for your help!
  • oner_erol Sep 18, 2010
    I changed the capacitor and STILL SAME PROBLEM!!!
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
Cerfer39
  • 709 Answers
SOURCE: Hoover Condensing dryer malfunction
Hi Mike,
The motor probably has experienced locked rotor current and fried the windings. Of course the capacitor could have shorted. If you can find it, look at the capacitor and if the can looks like it's lid is swollen or pooched out, then go for replacing the Capacitor. If you remove the motor and smell the case and it smells burned, you motor is shot. It does not have to lock down to be bad. The windings do not rotate in an AC motor.
Posted on Nov 03, 2007
  • 114 Answers
SOURCE: How do I change the
no brushes on it i think, ur looking at changing the capaciter if its not turning
Posted on Sep 24, 2010
tophatnation
  • 3 Answers
SOURCE: Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
Posted on May 22, 2012
May 14, 2012 | Hoover VHC391 T-80 Dryer
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
My hoover nextra8 condenser tumble dryer turns on but does not spin, checked belt and is ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Hoover HDC6 Electric Dryer
DRYER RELUCTANT TO START TUMBLING AND OFTEN WONT REVERSE..IT GETS STUCK WITH A HUMMING NOISE
Check the motor...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Jun 08, 2010 | Hoover HDC7FME Electric Dryer
Hoover tumble dryer
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Hoover HDC7FM Dryer Logo
94 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
