Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is spark plug gap for pp4218av saw - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
  • 25 Answers
.025
Posted on Sep 21, 2010
Change plug an won't start
Make sure you have the correct spark plug for your maching. and Make sure the gap is correct on the spark plug. Look in your owners manual for the correct gap. Check inside the spark plug wire end that connects to the spark plug and make sure the metal part is still in there to make the connection to the spark plug.
Jun 10, 2014 | Husqvarna Partner Gas Powered Cut Off Saw...
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Mar 20, 2013 | Stihl Garden
Will not start have checked fuel lines ok,cleaned spark plug ok,checked wires all checked ok,saw eas running fine shut off to change chain and refuel and would not start after
Just check that it has not picked up on the piston, remove the muffler and check the condition of the piston through the exhaust port, any sign of scuffing and the saw will need to come apart for further investigation.
Apr 06, 2011 | Poulan Pro Pp4218av 18" Gas Chain Saw...
Chain saw won't start
Before you try to start it, push the primer bubble on the side 3 or 4 times, then pull the choke all the way out. On poulans they can be tricky. When pulling the choke button out, make sure it does not go back in. After you pull the crank rope and you hear it "hit" push the choke back in and pull the crank rope again. It should start after that. If it still won't start, check for a faulty spark plug.
Aug 22, 2010 | Poulan PP4218AV 18" Chain Saw
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I...
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
May 05, 2010 | Poulan PP4218AV 18" Chain Saw
I neen repair manual for a Poulan Pro SM4218AV.
Hi Lou; great name.
What are you trying to repair? The correct IPL and some thought works for most things.
Poulan "PP4218AV Type 2" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4218AV-Gas-Saw-Type-2/75.PP4218AV-Gas-Saw-Type-2.1.59.1.html
If this is not your saw you can find the correct one here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Reply below with some additional detail of what you are looking and we will continue. HTH
Lou
I was born May 1950. Which of us has been Lou longer?
Feb 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the gap setting on a poulan pp4218av chain saw between the coil and magneto
You need something non-magnetic. Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Card stock is usually 0.0085 - 0.0095"
If you still have no spark after assembly please reply below and I will happily assist you. HTH
Lou
Feb 07, 2010 | Garden
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Wont start
remove the muffler and see if there is scoring on the piston.if ther is the saw needs piston and cylinder.sound to me that there is a lack of lubercation to the cylinder
Oct 09, 2008 | Poulan PP4218AV 18" Chain Saw
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
209 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
