Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice Maker water drips at the back of the container near turning moter and will not dispense ice cause the water has become frozen?
I have a repair man here now..My water condensation drain was covered with ice. at the bottom of my side by side freezer. the drain had ice over it..Its just a hole , that has to have warm water poured in it once every year..hope this helps you..L
Posted on Jun 26, 2008
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
The water dispenser has stopped working all of a sudden...a little water drips out, but that's it
Make sure water valve was not turned off,
Check water Filter,
Empty Ice container to see if you have problem with ice maker.
if water filer is good & Ice maker are working good
Then there are only two things it could be .... The internal water valve or the line is frozen
Most common is water valve in the refrigerator.
Oct 06, 2010 | Jenn-Air JCD2389G Side by Side...
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not getting water, water dispenser is. there is notheing frozen but the line leading to the ice maker doesn't have any water in it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 30, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Ice maker makes ice cubes, but the doesn't dispense ice cubes.
If you could observe exactly where the water is dripping from it would help but...If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 19, 2009 | Refrigerators
Our icemaker cannot make ice so we were using small ice in the ice dispenser. Now the ice dispenser does not work. When we first started having trouble with the ice maker we immediately changed the...
Both of those are controlled by a voltage signal sent to the back and rear near floor of the back of your refrigerator. The part is a water control valve. When you press the dispense water button the valve if not defective will open and allow water to travel through the bottom fresh food section water reservoir to the cup. When the ice maker dumps fresh cubes to the tray to store foe dispensing ice it also opens the valve for its side fore just enough time to refill the ice maker. Then the ice maker waits until it senses frozen ice and begins the cycle by heating elements below it to loosen the cubes to begin the cycle again. So get someone to unplug the side on pack and put the probes of a multimeter into each female side and press dispense, you should see 120 volts there. If not the dual water control valve needs replaced. Part Number 4389177
Sea Breeze
Jul 15, 2009 | Refrigerators
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
