Microsoft Windows XP Home Edition Logo
Posted on Sep 17, 2010
Print screen of web page - Microsoft Windows XP Home Edition
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Sep 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
8688
Points
24
Press Print screen button. Launch MSPaint application. And press Ctrl+V buttons in same time.
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
Some times i want to print some pages from the web but i cant found the print screen key. i print with right click and then save as but sometimes this way not success to save some pages so i want to know...
The best way to print a WEB page is ti click on File - then click on Print (or press Ctrl+P) and then select your printer if it is not the default printer.
When I try to print a page from the web, it prints what looks like code. It will not print the actual page that is front of me on the web. However, if print from Word Perfect, it is fine.
It's not your printer problem. The web page size is different from paper size. For these reson when you select whole web page, the web page divide more sector and at these time your printer print one of them or more.
Here is a software that help you to print the web pagehttp://www.printpunk.com/downloads.htm
Or,
There are some web site to print web page.
Jast go to the web, paste expected web address and try to print.
Or
If you are wondering why you can't just click the print command and get the web page or other internet page you're looking at to print out properly, you're not alone. Too often pages get cut off at the margin so the ends of lines are missing or pictures are cut off, or blanks appear where words or images should be. This is pretty frustrating because you can see the words right there on the screen; they're there, but when you print them out they're gone.
Never fear-- we a have a few how to tips and tricks for you to get those internet pages to print out nice, neat and complete.
First Click on Print Preview
Before you print out a page, go to your browser menu (usually the file menu) and click on print preview. This will bring up images of the web pages as they will appear on a print out. If they look good, all you should have to do is click the print command, usually also found in the browser menu file window, and they will print out as shown. Note, however, that once in a great while the print preview will not be accurate, and the print out will not match the preview. But don't tear your hair out, just make use of the tips that follow.
Look for the Printer Friendly Link
Some pages will have a "printer friendly" or "printable version" link or the like. Click on this link and you will get a version of the web page or pages that is optimized for print out. Once you have brought up this printer friendly version, just click on your print command found in your internet browser window. You might still have some problems if you are printing on a black and white printer, which we will discuss later, but otherwise you should get a faithful print out.
Also Look for the Pdf File Link
If the page you've called up comes up as a pdf file, you should have no problem printing it. If it is the usual html file, it may also have a link that will take you to a pdf file version of the same pages. Look for this pdf file link and click on it to bring up the pdf file. To read this pdf file, you will need a copy of adobe acrobat, which you can download for free by clicking on this adobe acrobat link. Remember that once you're in a pdf file, you should click on the print command in the pdf file menu, not on the print command found in your internet browser window. Clicking on the browser print command may cause all kinds of problems, depending on how your computer is configured.
Print in Landscape Instead of Portrait
If the print preview shows pages cut off on the margin, and you don't have a access to printer friendly or pdf versions, you can print the pages out in landscape instead of portrait format. If you don't know already, landscape prints left to right across the longest dimension of the page (as in a landscape painting) and portrait prints out the normal way (as in a portrait painting). When you print in landscape, you are pretty much guaranteed that nothing will get cut off at the margins. In most browsers, you go to the file menu, click on 'page setup', and in the page setup window click check the landscape box before you do your print out.
Black and White Printer Problems
Some black and white printers do not convert all the colors to black or gray causing some elements of pages not to print out at all. You get blanks spaces instead of words or picture. I have a black and white printer that does not print out blue. This is really aggravating when printing out text that contains a lot of those blue underlined links. You are reading a sentence and suddenly there are missing words.
There are a couple of solutions here. The obvious one is to print out the pages on a color printer or a different black and white printer that does not have this problem. Another solution is to cut and paste the web page into another program such as a word processing program. In many cases you can just then print out the pages and they will print fine. In other cases you will have to use the software program (that you've just pasted the page into) to change the problem color portions to black and white, and then print out the pages.
Problems Photocopying Web Page Print Outs
Sometimes a page prints out fine on a color printer, but you have problems copying color portions on a black and white photocopier. A lot of photocopiers don't copy yellow well. This may be intentional, as it allows you to get good copies of things written on yellow legal pads, and to eliminate yellow highlighter marks from pages you have marked up. However if the yellow is content you want to keep, it just gets lost. Try another photocopier; they don't all do this. Alternatively, print out on a black and white printer before you photocopy.
When All Else Fails
If you still can't print out successfully, you can try another web browser, or you can email the webmaster or other contact for that website and ask for a fix, copy of their catalog or whatever ot
Printer will not print the content from a website. The only thing that prints is the footer. Even when the Print preview shows all of the content on the web page, it will not print on the paper.
Some web pages are made up of two or more frames. If you use the Print button on the toolbar, only the active frame will be printed. To print the web page at it appears on the screen or to print only one frame use the Print dialog window to select what you want to print:
1.To print the web page including all the frames, in your web browser, click the File menu and select Print. In the Print Frames section, select the radio button next to As laid out on screen and click OK.
2. To print one frame, left click once on the frame you wish to print to select it. in the Print Frames section, select Only the selected frame and click OK.
Alternate method: Right click on the frame you want to print, choose Open Frame In New Window, then just print it out from the new window that opens as you would a non-frame web page.
Note: In Windows Internet Explorer version 5 or above, framed Web pages are printed with each frame coming out on a separate page by default.
I want to copy and paste a web page to adobe photoshop. Control print screen control paste doesn't work...any advice
You need Adobe professional to acquire the web page or use the print screen feature through Microsoft word then import.
2helpful
My printer will not print off the web, it prints my documents, but not off the web
Make sure that you are using a postscript driver and not a PCL driver. Many web pages will not print correctly to a PCL printer. Also ensure that the web page your printing is print friendly. Many pages on the web do not print if they use DIV layers. These pages usually have a "print friendly" link somewhere on the page.
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
This only happens when I am trying to print a web page. I do a print preview and I see about 10 pages of text that have no relation with web page that I am viewing on the screen. When I print , the same...
software issue of the browser, no printer prob. You didnt tell us what printer you run. Search printers manufacturer webside for a update if the print preview belongs to printer software, else your browser needs an upadte.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
