Question about EliteGroup P4VMM2 Motherboard
Want to disable onboard graphics to install and use pci vga card
I would like to install and use a recently purchased GeForce 6200 PCI VGA card. How do I disable the onboard graphics prior to installing the new card and its drivers?
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
Posted on May 17, 2008
Win xp will not shutdown installed new Nvidia Geforce 9300GS PCI
hello sir
u need to do two things
*deactivate the onboard vga adapter from the bios
*and install the official lates driver for ur card
if u can't find it tell me wht's ur operating system i will provide u a download link
Feb 13, 2013 | Nvidia Geforce 9300GS, PCI Express Video...
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
HOW CAN I INSTALL A NVIDIA GEFORCE 7200GS ON A HP 500B DESKTOP PC. IT IS CONFLICTING WITH THE ON BOARD VGA, THIS IS PREVENTING ME FROM USING THE GEFORCE AS A SECONDARY DISPLAY WHICH THE REASON I BOUGHT IT
It appears that you have spent real time and money to upgrade your system.
I understand your problem. You want dual output VGA's to have two monitors setup with your system. The computer, HP500 has an onboard VGA out, and your add-on PCI express will not give you a second out VGA.
More than likely, HP / Compaq might not support this configuration with thier CMOS>
Maybe better soloution would be since you already have a VGA and DVI video outputs from your new PCI express board would be to go into BOIS and disable your onboard VGA. The VGA should then revert to the new PCI express board. You then could connect the second monitor to have both on the PCI express board. If you have only VGA (blue type) connectors, you can get a DVI to VGA adapter.
At Newegg online or Tiger Direct should have them if needed for less than &10, plus S&H.
Good Luck
Aug 13, 2011 | Nvidia GeForce 7200 Graphic Card
I have a new geforce 6200 evga hd card and have installed it in a PCI slot after first having disabled my ASUS integrated ATI 3300 video through the device manager before powering down and installing the...
I am presuming that the mainboard is an Asus model with integrated VGA.
In order to perform the following steps you may have to remove your new VGA board and reconnect your monitor to the mainboard VGA in order to have a display on your monitor.
If your new VGA board is an AGP or PCI express, connecting your monitor to the new VGA board should have been detected and applied the VGA output through the new board. If the new VGA board is a PCI type then go to the new steps to make changes to your CMOS via the BIOS settings.
If not the Asus mainboard may have to have the CMOS setup change through your BIOS settings.
Upon bootup you should be able to hit the delte key and the BIOS screen should come one.
Scroll down to the a view that will show "Onboard Settings" or similar wording.
Select and disable the Asus onboard VGA or video.
If problem still persist, then go to the Assus.Com web site for support on your model Asus mainboard for the maunual, or trouble shooting questions on settings.
Good Luck
Jul 02, 2011 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
When i install my video card the screen is blank
Use onboard graphics and enter the BIOS/CMOS by pressing the delete key during boot.
Go through the options, some-where there, there should be an option to enable PCI-Express slot, PEG when one is inserted. This need to be set.
So onboard VGA is disabled unless PCI-E Graphics card/PEG is inserted.
damnor01
Jan 25, 2011 | PNY GeForce 6200, AGP Video Card
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
How do I disable vga on ga-8vm800m?
During boot press DEL to get into standard BIOS settings, while in standard BIOS hold CTL key and press F1 this will alow hidden features to show in BIOS. Enter into Integrated Peripherals and you should now see a entry called INIT DISPLAY FIRST and you should be able to select between PCI Onboard and AGP (Depending on what you have installed). I have the same motherboard and had also upgraded to the 6200 which works great after finding the hidden BIOS features.
Hope this does the trick for you!
Jan 29, 2008 | Gigabyte GA-8VM800M Motherboard
AGP slot
try a 3 way monitor vga switch 1 imput and 3 outputs to your monitors
Dec 14, 2007 | HP Pavilion Media Center TV m7360n...
EliteGroup P4VMM2 Motherboard Logo
304 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
