Question about Quintum Tenor ASM400 (501-0133-00) VoIP Terminal Server
24 port quintum locked up. No dialtone - Quintum Tenor ASM400 (501-0133-00) VoIP Terminal Server
I need quintum axt2400 support
In case you need support from outside (remote location) for fine tuning you tenors just provide me the IP Address and Password via mail and, or chat; contact me as bdheeman (at) gmail (dot) com.
Dec 29, 2012 | Quintum Tenor AXT2400 (501014800) VoIP...
Quintum DX Issues connecting to a static route which used to work before
could be bad rought u unplug it fr wiel and cool it down plug back in is it getting hot do u have fans on your roughters
Jan 25, 2008 | Computers & Internet
Several problems, please help
try to debug test the line .. maybe one of the line are loose..
Mar 01, 2009 | Quintum Tenor A800 (501-0026-00)
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
Quintum DX2024
These links will help you:
http://www.quintum.com/support/xplatform/ivr_acct/webhelp/ANI-based_Post-Paid_Services.htm
http://www.quintum.com/support/xplatform/ivr_acct/webhelp/Pre-Paid_Application.htm
Jan 06, 2008 | Quintum Tenor DX2024 Router (501011500)
Speed dial
For System Speed dial, you can only do it from a port with Attendant Features. Typically they are ports 1 and 2.
Assuming they are still the default settings, the available System Speed Dial bins are 00 thru 79.
from one of the Attendant Ports:
Press Feature
Press Redial
Dial in the memory location bin number (00-79)
Press "9" for the Trunk Access Code (or whatever it is)
Dial in the Phone Number (24 digits max)
Press Feature
To use, get DialTone, press Redial, enter bin number (00-79)
Oct 10, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Quintum DX2060
http://www.quintum.com/support/products/2G/tenor_2G/sysdoc/webhelp/calleridgeneration.htm
Try the search box at this URL: http://www.quintum.com/support/
Just copy & paste the parameter name into the box.
Jan 13, 2007 | Quintum Tenor DX2060 (501-0122-00)...
Quintum Tenor ASM400 (501-0133-00) VoIP Terminal Server Logo
71 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
