Question about Keurig Platinum B70 Coffee Maker
The machine says, not ready - nothing else on screen. Pressing any button changes nothing.
  • 3,083 Answers
I wrote this before I found the video at the end:
You should contact Keurig about this problem, because whatever the problem is, it's going to require disassembly and troubleshooting the problem. A sensor or switch could be faulty, a valve dirty/stuck/broken, the heating element open, or you could have a faulty control board. Sometimes it's something as simple as an oxidized contact on switches and wires, and simply disconnecting and reconnecting them can solve the problem. They don't make disassembly easy on most things since they really don't want you to fix it, and that's the rub. Sometimes they use security torq head screws to discourage home repair. Here's the contact number for them if you need parts or help, taken from wholelattelove.com
the machine says, not ready - nophoto.jpg Carol Alix
Ask the Experts Question Where can I get Kethe machine says, not ready - button_a.gifbr />
button_a.gifAnswer All parts, tech advice, and repairs go directly through Keurig. to reach them, please dial 1-866-901-2739.
Actually, I had written this answer before I found this video:
http://www.youtube.com/watch?v=xjWIQpttTc8&feature=related
Hope this helps you. There are more videos on that page which address different problems, and might be useful.
Good luck, hope this helped, and thanks for using FixYa.
Posted on Sep 17, 2010
Ge front load washer wbvh5300koww
You have either a faulty door latch switch. Or the actual Button is faulty. PRAY it is the door latch switch. Because if it is not you have to replace the entire button assembly which includes the command module and LCD screen....Yikes! That is $400+
Jan 19, 2014 | GE Washing Machines
Kyocera machine displace C6000 call service
enter the service mode by pressing 10871087 .there will be U000 then press 163 through keypad then press START button 4 times machine will restart .wola. check ur input voltage it is fluctuating
Jun 02, 2011 | Kyocera KM-1510 Copier
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Aug 10, 2009 | Keurig B60 Coffee Maker
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Keurig Platinum B70 Coffee Maker Logo
213 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
