I have a Philips turntable but the Cartridge is bad (RC IZ 215 ) and another Philips turntable in which the Idelar is bad ----am desperately looking for the spare parts.Please help.
    Champion:
  • 271 Answers
Hi. stylus city ccan supply a replacement cart for your Phillips. We can also rebuild your idler wheel. Styluscity@gmail.com
Posted on Sep 18, 2010
Could I conect philips 660 turntable with receiver
As long as a Magnetic Cartridge is fitted to the deck and that the receiver has a built in pre-amp for a Magnetic Cartridge, then it will work. If the receiver does have the pre-amp you will need to purchase one separate.
Nov 16, 2014 | Audio Players & Recorders
We have purchased a Philips AF 729 Mark II turntable, where can we purchase a stylus for this model and/or what would be compatible to replace this with?
The styus is a function of the cartridge, not the turntable.
For example, this one is sporting an ortofon cartridge of some sort.
http://www.classicaudio.fi/fi/index.php?mact=classicaudiocatalog,cntnt01,default,0&cntnt01what=kohde&cntnt01alias=Philips-AF-729-Mark-II&cntnt01returnid=67
While this one is somethng entirely different...
http://cgi.ebay.at/Philips-AF-729-MARK-II-hochwertige-Plattenspieler-/180639747902?pt=Plattenspieler&hash=item2a0ef7cf3e
Identify YOUR cartridge if you just want a stylus for it. Then search for that online. The mount is fairly standard if you really want a whole new cartridge. But cartridge alignment and mounting are tricky without the original jigs that usually accompany a good turntable.
Apr 20, 2011 | Philips Audio Players & Recorders
Looking to upgrade the cartridge/styli in my ion audio profile pro turntable. What products/company/style should I be looking for?
I have the same turntable, and sadly the cartridge is proprietary and unable to be changed. However, you can still upgrade the sound quality by replacing the stylus to a higher quality needle. I did that for about $25 and feel better about playing my precious vinyl. The biggest problem to this turntable is the lack of anti-skate. That's very bad...
Mar 27, 2011 | ION Audio Turntable Cartridge Replacement
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
Aug 10, 2008 | Philips Audio Players & Recorders
Ibm wheelwriter 30 series 2
215 indicates a printwheel error. Remove the printwheel, look for debris in the P/W cartridge and the area where it sits blow out the P/W area with air if the problem dosen't go away the sensor is probably bad.
DickyO
Apr 01, 2008 | IBM Wheelwriter 30 Typewriter
55 people viewed this question
 Grubhead
Grubhead
