Question about Kenmore 24032\24036 Top Load Washer
Buzz couldnt find a part called motor coupling can you help??
  • 868 Answers
  • This is the coupler .If you locate the motor underneath the washer,than look for this part right where motor joins the transmission.
Posted on May 23, 2008
I have a maytag 2200 dryer and it just buzzes and the motor does not turn. The problem is intermittent, it will work fine for a while then just buzzed again until something kicks out. I have disconnected...
In your case it sounds like the motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Dryers
Washer not spinning
If you are neither spinning nor agitating and you can hear the motor running (humming or buzzing) the the problem is with the coupling. See the first link below to repair.
If the motor does not run, only fills, no drain, no buzz no hum then the problem is most likely with the lid switch, see the second link.There is video near the bottom of that page showing how to replace it. Let me know if this helps.
Coupling
Lid Switch
May 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Maytag neptune dryer wont start hums for a couple of seconds then turns off
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
heatman101
Apr 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is making a buzzing sound and not starting RoperRED4440SQ0
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
heatman101
Apr 11, 2010 | Dryers
The timer makes a loud buzz sound and the dryer will not start
heatman101
Apr 09, 2010 | Maytag PYE2300AY Electric Dryer
Motor is noisy (loud buzzing). Drum belt seized.
the problem, is with a component,called a capacitor.a capacitor gives a"jump start"to the motor.when this charge or jump start cannot be given,the motor will "hum" or"buzz".a new capacitor should not too expensive.
Oct 16, 2009 | Tricity Bendix TM310W Electric Dryer
Washer fills up for rinse cycle put never actually spins
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
P.s Remember to unplug the power prior to servicing.
Aug 06, 2009 | Whirlpool Washing Machines
Kenmore 70 series top loader wont spin just loud buzzing motor noise is there a belt or are these direct drive
that is called a clutch coupling and is located behind the motor not an easy repair to do but very fixable
remove jacket of washer .remove pump.then motor
install new coupling
Apr 17, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
15 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
