P-Touch Label Maker: How to get rid of "Text Too High! 1 Block" error message?
You may get this error after installing new tape which is small in width. If you reduce font size, so it will fit on new tape, the error message goes away and your P-Touch will print your label.
Posted on Jul 17, 2013
3 Suggested Answers
SOURCE: Error 1 message
Check the batteries and that there is nothing clogging up the tape area. Any little bit of tape can cause the error message to come up. Also if you put in say 4 new batteries and kept 2 older ones that show a little life still left, can cause the error message. Change all the batteries at the same time.
Posted on May 08, 2009
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
Posted on Jul 20, 2010
P-Touch 7100 cutter error
Just a (too late) suggestion: The cutter on the PT-7100 (and I think on every Brother Label printer that uses TZ tapes) has a replaceable blade. Sometimes just removing the blade and making sure the tape path is clear of gunk is all it needs.
Apr 07, 2015 | Office Equipment & Supplies
How do i block txt messages
how to block unwanted text messages.
Nov 20, 2014 | Cell Phones
I'm trying to print a label. Message says Text Too High. What is that exactly?
You have selected a font size that is too large to fit on the label. Or you have selected multiline with too much data.
Nov 11, 2014 | Brother P-Touch 1180 Label Printer
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
What does "Text too high"
When you push the print button, "TEXT TOO HIGH!" error message appears on the LCD display, why? Description: This message appears if the size of the text is larger than the width of the installed tape.
Please reduce the character size or install a wider tape.
Aug 12, 2011 | Brother P-Touch 1180 Label Printer
How to block samsung corby?
Reject list for Samsung:
To Reject Calls:
Recent calls
All calls
Options
Reject list
To Reject Text Messaging
Menu
Messaging
Messaging settings
Text messages
Block number
Oct 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
5,496 people viewed this question
jasbo
jasbo
