Question about OKI MICROLINE 320 Turbo Matrix Printer
OKIDATA Microline 320 9 pin (Turbo) Printer doesn't print. Documents not in queue. Worked fine until new computer hooked up. Now sometimes will print if turned off and then back on. Re-install drivers? Thanks for your advice, Judith Walling
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
freetek
  • 5568 Answers
SOURCE: Microline 320
Looks like you can get the non-T manual from the Oki site:
http://my.okidata.com/PP-ML320.nsf?opendatabase
Posted on Aug 26, 2008
SOURCE: microline 320 turbo won't go into menu mode
just use the buttons, SHIFT+SEL(MENU) with the printer on and you will see the MENU light
Posted on Sep 19, 2008
  • 40 Answers
SOURCE: okidata microline 320 turbo 9 pin printer
What driver are you using, you should try the IBM Proprinter Driver.Hope this helps.
Dezzi
Posted on Nov 29, 2008
  • 8 Answers
SOURCE: okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Posted on Jan 16, 2009
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Could you please tell me why my printer is printing each line to close to the line above and how to solve this problem . I have a microline 320 turbo oki 9 pin printer,
could you please tell me why my copier isn't printing the copies dark enough-could it be the ink cartilage or another problem. I don't want to order the cartilage if it is another problem. It is an older copier-PC941
Oct 16, 2009 | Matrix Okidata Microline 320 Printer
Okidata Microline 320 works with cover off only
i think its time to update your printer. but if you want to keep it then maybe the cover is not put on the right way or it is blocking the process described. in these cases you can't really solve it.
Dec 19, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320 turbo won't go into menu mode
Sep 05, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320
Aug 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
New hookup - warning light going on
Take the ribbon out and try it. The carrige also advances the ribbon, and if it is knotted up, thats the problem. Also. look for a photo interupt sensor along the edge of the carrige near the sides of the printer. Chances are, the sensor got dirty and it can not find home.
Mar 08, 2008 | Office Equipment & Supplies
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320 turbo 9 pin printer
Dezzi
Feb 11, 2008 | OKI MICROLINE 320 Matrix Printer
Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
132 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
