Question about Hitachi 36UX59B 36" TV
Intermittant white line with subsequent shut down
I have had this set for quite a few years without incident. Recently, with no discernable periodicity; a white horizontal line with no picture pops up(black screen above and below the horizontal line in the middel of screen) in the middle of the screen and after a second or so tv shuts down. If we unplug the set and let it sit for a couple of minutes and then plug it back in--it will sense input from satellite receiver and turn back on. Sometimes it shuts off 3 or more times in a 30 minute period and sometimes it will go all day with no problems/
    Scholar:
  • 131 Answers
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
Posted on May 17, 2008
Will start and drive fo 10 miles quits starts up again drives for 4 or 5miles quits is this the fuel pump
Sounds more like a electrical issue, perhaps a bad computer. I had one case where the oil sending unit had a broken wire inside the insulation. When the car was cold it ran fine, once it heated up it would spit, sputter and quit. The problem was intermittent and totally unpredictable as to when it would do it next. I finally tracked down the problem, and subsequently learned (even though the service manual made no mention of this) that the computer will shut down the engine if it detects a low/no oil pressure reading from the sensor, which is what was happening, since the computer would get a zero reading when the wire separated. It may be wroth looking into, you may have a similar issue. Rare, but did happen!
Mar 15, 2015 | Cars & Trucks
I have a recently purchased RS 2664 RCA shelf
If the wires got crossed and/or touched each other at all - that could certainly damage the amp(s).
Also - if the system is not made for extra speaker - that would change the ohmage - and that could aslo damage the amp(s)..
Or maybe the system designed to protect the amp(s) was damaged..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Audio Players & Recorders
BMW 740i Stalling Issue (Fuel Pump/Line??)
the problem is your sensor is bad . the sensor for for the fuel pump is not sending power.
Feb 23, 2009 | 1985 BMW 3 Series
1993 BMW 740i Stalling Issue
check the fuel filter and if old replace it and if that does not work, change fuel pump and strainer.
Jan 21, 2009 | 1993 BMW 7 Series
To save you all the hassle check your spark plugs & distributor first if you are getting a spark. To do that first take out the number one spark plug wire it will be the one closest to the distributor. Second take out the spark plug, then put the spark plug in the spark plug wire. Turn on the engine u should see a spark at the spark plug if your distributor is ok and spark plug. If not replace your distributor.
Jan 21, 2009 | 2001 BMW 325
Engine Shuts Down Intermittently
iac motor, is a problem this time of year
Jan 06, 2009 | 2000 Cadillac Eldorado
My brakes lose power system intermittently
It's quite possible you may need to check out your ABS system. Certain GM light trucks of that year, and a few in subsequent years had issues with the EBCM (electronic brake control module) These units are mounted on top of the ABS valve body, under the vehicle, on the left frame rail (all the brake tubing is attached). Sometimes the faulty unit would cause the electric ABS motor to continue running even after ignition shut down. Sometimes they would cause erratic ABS actuation.The other thing may be a faulty vacuum check valve at the brake booster. If that valve goes bad, your brake pedal will be really high and hard to depress. On some 1/2 ton GM trucks with vacuum assist power brakes, there is an electronic sensor that measure vacuum to the booster. In those instances typically a warning message will come across the drivers info center on the instrument panel. I hope this info can help.
Nov 14, 2008 | 1999 Chevrolet Silverado 1500
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Pictures taken during the day come out VERY bright, even white
Might be worth flicking through all the settings menus for a few minutes - look in particular to see if you've got it out of Auto into Manual Exposure, or if somebody has accidentally selected a "brighten everything up by a couple of stops" mode. A.
Jun 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hitachi 36UX59B 36" TV Logo
163 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
