Question about Frigidaire Model: FRS3HR5HW
Display was blinking on number four now the compressor kicks on and off then quits all together can you help me
If my TV just quit working and for no obvious reason , does the indicator light that blinks four times repeatedly mean anything
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 23, 2016 | Panasonic Televison & Video
Maytag model mfc2061kes just stopped working. The control panel just blinks 888 when we try to reset it. We unplugged it and cleaned out all the dust,plugged it back in and nothing is on the display panel.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Maytag MFC2061KES Stainless Steel French...
I stopped using my tender three weeks before moving. I switched it off and then switched in on in the new house and the display blinks, and the unit doesn't cool. The fan seems to work on low but...
NOTE: This
Leo Ponder
Sep 10, 2011 | Krups BeerTender B95 Beverage Dispenser
The Freeze door was left open for days and now both the refer and freeze do not get cold. Is it possible the unit is beyond repair and the compressor quit working? Its a Whirlpool side by side thats 11...
NOTE: This
Leo Ponder
Sep 07, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Amana ACD2234HRQ quit working. Only have slight humming sound
NOTE: This
Leo Ponder
Aug 19, 2011 | Refrigerators
It ran great until yesterday it sounded a little different and then quit cooling.
NOTE: This
If this doesn't work Do this
That is probably the compressor relay
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Engel 14 Qt Portable Freezer
Compressor not kicking on model refrigerator
Sounds like the cold control has stuck open. Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
That is probably the compressor relay or cold control (Thermostat
Leo Ponder
Jul 31, 2011 | GE Refrigerators
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
My freezer quit working. It is four years old and this is the first time I have had trouble with it. My frezer makes no noise when I plug it into the outlet. I did try to use another outlet with no luck.
See if you can spot any fuses in the back by the compressor. it may also be a relay switch by the compressor. You can also tap the compressor and see if it stuck and last, the therostat may have stuck on you. If you take it out and just coss the wires to each other then if it is that the compressr ill kick on. You can't leave it like that though. You will have to get another one. Be sure you have it Unplugged when crossing the wires and then plug it in after they are tied together. I think its low voltage going to the thermostat but you want to be caustious.
Please be kind and leave me a thumbs up for my effort. I am doing my best to save you some serious serve call cash. The Raz Shack
Apr 05, 2010 | Frigidaire 13 cu. ft. / 368 liter Chest...
Freezer says "of" on display
I assume that stands for off... there are 2 parts that affect compressor operation...
t'stat
timer
t'sat could keep the compressor from running if it is bad. to check unplug freezer. . get to t'sat and take the 2 wires off it. then jump them together.. plug back in if the compressor kicks on he replace t'sat if it dont replace timer (timer maybe stuck in defrost)
jope this was helpful
Mar 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire Model: FRS3HR5HW Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
