Question about Hotpoint WD62 Front Load Washer / Dryer
Carbon brushes have been changed but drum still does not spin any ideas of what it might be and how to fix it? Pump and dial seems to be working fine, belt is also fine
  • Hotpoint Master
  • 1,525 Answers
Hello any spin problems usually down to the module board . theres circuit board at the back off the washer it may have a few wires coming off it the transistor on the board may be running hot
regards
shaun
Posted on Sep 17, 2010
Why won't the drum spin on my washing machine and can I fix it myself
Very likely the brushes are worn, these are located either side of the motor. if you are able to take the motor off the machine but don't know where the brushes are, take the motor to your local repairer who will probably change the brushes for you at a small fee plus brushes. if you are able to identify the brushes and can take them off, the carbon inside the brush holder should be no less than half and inch long. If its less they are probably worn out. get new ones and replace. be careful the carbon brush is very brittle and will break easily. I can't be more specific on changing the brushes as each machine is different.
Oct 17, 2014 | Tricity Bendix Biw125w Washing Machine...
Zanussi fs1455w not spinning fast under load. Without anything in the drum it spins fine??? Tried all speeds with the same result. Any ideas???
May be not pumping efficently. when the spin starts the initial rush of water floods into the drum from the clothes a build up of water under the drum causes a braking action on the drum and slow spin speed.. look for partial blockage in pump chamber hoses or under sink if a spigot connection. probably not the belt as it would throw off a loose belt. Check it anyway. if non of these check carbon brushes they may on the verge of failure.
Jul 23, 2010 | Zanussi FS1455W Front Load Washer
I have a Hoover Vision 1600 plus that has stopped spinning. Water pump works, water inlet works- drum will not spin. Help!
Could be motor or motor brushes you could remove one carbon brush check if its worn should be at least 1/2 inch left in order to funtion well
Apr 01, 2010 | Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Trying to change the carbon brushes but can't find a socket the right size any ideas?
all done it was the brushes on both sides of the motor and borrowed a tool set to do it only cost £7 each and the machine is back on
Apr 28, 2008 | Tricity Bendix AW1400W Front Load Washer
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
WD62 is not spinning even after chaning new carbon brushes
when u changed the carbon brushes did u move the little metal pin to free the carbon off it must be able to come out then in with ease if not do this if u did then if the carbon brushes have got too low then it will have more then likely damage your motor m8
Feb 09, 2008 | Hotpoint WD62 Front Load Washer / Dryer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Dial turning for cycle but the drum will not spin
it could be your carbon brushes these are situated in your motor these might need replacing if they are 8ml or less they definetly need changing
Jan 22, 2007 | Hotpoint WMA31 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
