Question about Sony STR-V555ES Receiver
When I turn the receiver on the relay near the 110V input clicks ~3-6 times per second. When I disconnect the cable to the transformer the clicking stops. I suspect either the relay or transformer, since the relay is a mechanical device I guess that is more likely faulty.
SOURCE: Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Posted on Jan 28, 2008
  • 319 Answers
SOURCE: power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
Posted on May 01, 2008
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
  • 137 Answers
SOURCE: Sound clicks off Sony STR-DE835 5.1 Channel
THIS UNIT HAS BAD SOLDER CONNECTIONS ON REGULATOR TRANSISTORS,REMOVE BOTTOM AND YOU WILL SEE THE BAD CONNECTIONS.ALSO BE SURE TO RE-TIGHTEN ALL CHASSIC GRD SCREWS AS THIS WILL ALSO CAUSE THE SAME PROBLEM.
Posted on Apr 14, 2010
  • 979 Answers
SOURCE: Hi, Toroidal transformer in Sakura
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Posted on Dec 02, 2010
Testimonial: "Thanks"
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Feb 29, 2008 | Yamaha RX-V730 Receiver
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Dec 02, 2010 | Audio Players & Recorders
'clicking' off a few seconds after turned on
Does the receiver work OK?
These are probably electromechanical switches (called relays) which yamaha uses a lot. They use electricity to connect/disconnect something by magnetic force and this causes the "clicks". It is used for example to connect the speakers to the output of apmlifier only after it has finished initializing to protect both the amp and the speakers.
When I turn on my RX-V465 I hear at least one click, it is probably connecting power to the amp. When turning it on with Radio button on remote I hear 3 clicks over 2-3 seconds.
So these clicks are normal and nothing to worry about. They occur also when you switch to the PURE DIRECT mode.
Feb 27, 2010 | Yamaha RX-V463 Receiver
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
Sep 24, 2009 | Sony STR-DE525
What voltage will a HP 6715b accept?
hi no need of transformers.. ur lappy is ready to accept 230v-240v...
Feb 07, 2009 | HP Compaq 6715b Notebook PC
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
Sony STR-V555ES Receiver Logo
56 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
