Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
How do i replace batteries?i cant find an easy way to disasemble to replace batteries
  • 692 Answers
Eyeglasses In front of the seat there are the two seat support pipes extending out from under the seat. push in the buttons sticking out of those pipes and lift the front of the seat up. Now you should be able tosee the batteries. If you disconnect the joystick cable from the rear of the chair you can pull forwqrd on the seat and lift it off the frame. You might need some help in getting the seat off. Once you have the seat removed access to the batteries should be a snap. Hope this helps you
Posted on Sep 17, 2010
Cigarette/accesory units keep blowing fuses, not how for to dig to find short?? or easiest thing to try first. lol
I would start by replacing the cigaratte lighter first. Replacements are cheap and should bbe easy to replace. Check wires that attatch to the back of the unit when replacing. Make sure you have no ***** wires touching anything.
Nov 17, 2011 | 2003 Chevrolet Malibu
Scratch on screen need a replacement.
Replacing the screen is not an easy task on a plasma TV since it requires complete disasembly of the TV and removal of the plasma panel itself. Its not something I suggest for anyone but qualified personel to attempt. : )
Jul 25, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to replace battery in the Schiller AT-2 light EKG machine
The battery in the Schiller AT2 is as 12 volt 2.2 AH battery commonly available from R&d batteries, there part number is 5515. To replace it requires disasemble of the unit. Note that you should never disasemble this unit while it is plugged in. Also there are several cable that attach teh top housing to the PC board, and if you are not dillagent about not pulling these vcables apart while disasembling the unit, you can do expensive damage. Bearing that in mind, I would proceed as follows:Turn the unit upside down on top of a towed or other soft surcace to prevent scratching the soft plastic of the upper housing. around the perimeter of the case you will see several screws, i think 8 if i remember correctly. Repmove them and place them in a cup or other container. Grip the top and bottem cases together firmly and flip teh unit back upright. GENTLY lift up the top housing, and VERY CAREFULLY slide it about 3 or so inches to the left. This will expose the battery. just lift it out and replace it with the new one.Take care to reconnect the wires in the same position as teh original battery. Mis wiring the battery will cost you hundreds of dollars. The wires connect via slide on spade connectors. grip them by the connector itself(not the wire going into it) and gently rock it side to side while pulling, it will eventually come off the battery terminal. Resemble the unit in the reverse order. Plug the unit in and fully check it prior to re-installing the screws in the bottom of the unit in case you pulled a cable loose. As an alternative, you can detach the cables from the pc board and place the top cover to the side while replacing the battery, but be VERY careful with the cables. I recommend that you have a qualified individual preform this replacement for you. the cove being removed exposes high voltage, and also presents the risk of expensive damage to your unit.
Mar 22, 2011 | Schiller Welch Allyn Cardiovit At 2...
Disasembly of a phillips norelco shaver 7310xl in order to replace battery.
Remove the 2 screws on the back and remove the back cover. This will allow you to access the inner cover that has 3 screws. Remove those screws and take off the inner back cover to access the battery. Be sure to read the NOTE concerning installation on that page
You will find the battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Aug 19, 2010 | Health & Beauty
I have a Canon sure shot TeleMax with broken battery box door.
Yes, it's very easy to replace, once back cover is removed.
There are no diagrams available anywhere.
You'll have to remove all screws you see and remove first front cover and then back cover.
Apr 07, 2009 | Canon Photography
Problem with ma ibm thickpad
loose the back of yr ibm if u cant find the cmos battery then u might need to disasemble the whole system carefully under the key board i think thats where th cmos battery will be.
Note removing cmos battery in some systems dont clear cmos password u have to do some additional work to remove yr password. for the battery prob try using a diff battery to be sure what ur prob is.
thank u
May 26, 2008 | Computers & Internet
Battery was put in backward in camera cant get it out
You should probaly listen to the manual and take it to a dealer or phone Olympus about sending it in because it is probaly possible to disasemble the camera to get it out your self but doing so would void your warranty.
I hope you get your problem fixed!!
Apr 29, 2008 | Olympus Stylus 790SW Digital Camera
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
125 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
