Question about Poulan Garden
I have a poulan riding mower model# 96012001600 It has a kohler SV590 engine. when I try to start It the gas just pours out of it. Can you give me some advice?
  • platt_john10 Sep 18, 2010
    I got it fixed it was the float sticking . all I did was clean carb.
    President:
  • 2,777 Answers
The gas just pours out of the engine when you try to start it?! That is a serious problem.... can you see where it is coming out? Is it just dripping out or literally pouring? There is some gasket or valve that has cracked inside the engine, or worse :(... I need to know more though. Regardless it is going to need some major service. Call Poulan to find out how you can get it service: 1.800.849.1297
Posted on Sep 17, 2010
I have an older poulan pro 18 hp ohv.kohler engine. Tried adjusting throttle linkage to get more rpm. the throttle /carburator linkage plate has adjustment also. In what order do you start adustments
The Kohler is design for 3600 Max rpm with it developing peak torque at 2200 rpm 42.5 N·m (31.4 ft. lb.)
If your trying to go above the 3600 rpm then your only risking damaging the engine plus causing unnessary wear and tear on it.
Apr 01, 2015 | Poulan Garden
Oil capacity LTX1040 kohler motor
1.6 qts (1.5 liters) if you have the SV590
Oct 20, 2014 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan ride on lawn mower will not run by itself--if you pour gas into the intake it will run until the sm amt runs out
It could be your fuel shutoff solenoid is not working or is stuck from gum, varnish or rust in your carb bowl. The fuel shutoff solenoid is located on the bottom of your carburetor. To check it, have someone, or yourself if you can reach the ignition switch, turn the key to the on position and back off several times while you listen by the carb. You should hear a click each time. If not, the carb will have to be taken off and cleaned and checked. You will probably find water and/or rust in your bowl plugging up the main jet. Best to take it to a shop.
May 16, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Try to start mower and turns over but wont start unless you pour gas in carb then it will start and run fine. 1648s scotts mower with a kohler motor.
Does it continue to run after you start it by pouring gas into the carburetor or does it die again?
If it continues to run, it sounds like your choke is not working. Probably disconnected -- check linkage.
May 05, 2009 | Garden
Garden Logo
75 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
