Question about General Electric WCVH6800J Front Load Washer
The spin cycle of the front loader GE WCVH 6800J has a high ping noise (like a zipper hitting the glass) and wobbles and can't get up to the higher spin speeds. The wash cycle appears to be normal and doesn't ping or wobble.
SOURCE: Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
Posted on May 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Need the part # for the door seal for a GE front
The part number for the model you have listed is WH08X10036. I found your washer listed at pcappliancerepair.com, with a complete illustrated parts breakdown. Other sites you may try are:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
NOTE: For your search criteria enter your model number a "WBVH6240H0WW".
I found the gasket listed at repairclinic.com and appliancepartspros.com for the best prices.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 05, 2010
  • 4088 Answers
SOURCE: GE WDSR2120J wash cycle sound
It's possible that the tub suspension system is out of position. Open the cabinet top (use a thin putty knife in each front corner to release a spring clip) and watch the mechanism while washing. Try shaking the assembly to see if you can spot something rubbing. Hope this helps!
Posted on May 23, 2010
Testimonial: "Quick response with clear verbose guidance. Thank you so much :)"
normanocean
  • 51 Answers
SOURCE: Washer Part number-WBVH6240HWW. My Front
there is something between inner and outer tube
Posted on Feb 27, 2011
  • 32 Answers
SOURCE: My GE WBVH5200J2WW Front Load Washer is making a
if you put a large amount of clothes it will make this noise if not you will need to replace the spring inside washing machine
Posted on Jun 10, 2011
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
My washer when it is on the spin cycle wobbles back and forth almost like it is off track somewhere buts its not off balance. It hits each side of the washer like its lose, and instead of spinning around...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 30, 2011 | Maytag Neptune MAH6700A Front Load Washer
My front loader shakes.. when in the wash and spin cycle
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Oct 13, 2010 | GE WSXH208A Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My ge front loader is making a banging noise while in spin cycle
When I was researching which washer to buy I read that this one is not the best choice to have on a second floor. Ours is on the main floor and can still be a little loud in the spin cycle. Have you balanced the machine properly? Otherwise, I think I read that people have had success putting a thick, dense rubber mat (like a stall mat for horses) under the washer to minimize the sound/wobbling. Good luck!
Patty
Jan 29, 2009 | GE WSXH208A Front Load Washer
Washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Jan 16, 2009 | GE Washing Machines
Brand new front load kenmore wobbles and moves across floor
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
General Electric WCVH6800J Front Load Washer Logo
37 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
