Question about GE Dishwashers
Our soap dispenser doesn't always dispense soap
  • GE Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 18, 2010
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
Hoover HD83 soap dispenser problem
My best guess would be a stick dispenser door. I believe this because if the timer was not working properly then the door would not open at all. I would decalsify the washer and if that doesn't work I would pull the door apart to see if there is somthing stuck in the dispenser that is jamming it up
Sep 06, 2012 | Hoover 24 in. HD83M Free-standing...
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
heatman101
Sep 12, 2011 | Dishwashers
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
Soap dispenser door will not open during operation
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Hope this helps... Please revert for any further assistance.
Daniel
Aug 26, 2010 | KitchenAid Dishwashers
Soap dispenser won't open during operation
Hi
Please do rate this solution and revert for further assistance.
Daniel
Aug 02, 2010 | Maytag Dishwashers
FQ106D1 Main washsoap dispenser always has soap in
remove dispenser drawer and give it a good clean.adrian,,,,
Jun 14, 2010 | Washing Machines
The soap dispenser door does not always open
the dispenser has to be changed. there is a spring that might not be spring back to open . its easier to replace then to get the kit and rebuild your dispenser.
Feb 24, 2010 | Dishwashers
Dishwashers Logo
188 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
