Question about Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop vac when turned on , no power, is there a reset button? or a fuse that might have blown?
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Shop Vac just stopped
Some do, but it would be in the open by the cord. But you could have a bad cord, switch, or a problem with the motor.
Posted on Mar 13, 2008
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
Model # 14rt350 shop vac won't turn on. Reset? Fuse?
Is it new? You know if you don't keep your filter clean and hose cleared of debris they don't last long never run without a bag and or filter unless sucking liquids and liquid only
Jan 08, 2017 | Shop Vac Vacuums
My 3.5 hp 8 gallon shop vac wont turn on. Fuse? Reset switch?
possible a start/run capacitor failure
take it to a vac shop for diagnosis and repair
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Mar 29, 2014 | Shop-Vac Corporation Bulldog 8 Gallon...
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
The vacuum shuts off by itself and then sometimes takes a while to start again after several attempts, progressive canister type 25914507
Sounds like your motor is cutting out from a thermal fuse. this means that when it overheats it will turn off and then will reset, allowing you to operate the vac. The problem could be a result of poor air flow...check the filiters and hose path for any blockage. If this is ok, then it may be a faulty thermal fuse or motor issue, in this case take it to a pro vac shop.
Oct 13, 2009 | Vacuums
Craftsman shop vac no power when turn on
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Power nozzle not working on my vac but does on another vac
Is there a reset button somewhere on the power nozzle? Most of these have a breaker to prevent the motor from burning out.
Feb 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Shop Vac 584-06-00 Canister Wet/Dry Vacuum Logo
1,606 people viewed this question
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
